20 Most Recent Samsung Dv5471agp 27" Front-load Gas Dryer Questions & Answers
you need to check the gas supply
and venting system for any problems clogs etc
there is a detection circuit just for these and its very sensitive
Samsung... | Answered on May 19, 2014
Only pace it could come from is vent isue in less its a steam dryer check dryer vent if its going down hill back to dryer change to straight vertical venting or if you do have a rise make a trap fitting wear water can be drained from time to time steam is water and steam will turn back into water after cooling
Samsung... | Answered on Jan 30, 2013
Take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manuals
Samsung Washing... | Answered on Jan 11, 2020
water valve measure look for mains on this contact a lamp on the waterintake solenoid wire lugs instead of the waterintake or an multimeter. if there is. control also washing machine faucet disconnect the hose. that there is not only a faucet problem, it can not be to difficult. by most other frontloaders there is a connector between the wire to that solenoid valve that it will be wenn a suspension bracket is broken then the movement result will be to great and then it pulled a connector loose so then there is no working water intake maybe only the programclock will move, look in the user manual if there is a troubleshooting for it. like a comparable way..
Samsung Washing... | Answered on Jan 10, 2020
A Samsung Washing Machine displays a Ub error code when a Load Balance Issue or Hall Sensor Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-washing-machine-ub-code/
Samsung Washing... | Answered on Dec 22, 2019
A Samsung Dishwasher displays a LE error code when a Leakage Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-dishwasher-LE-code/
A Samsung Washing Machine displays a tE error code when a Thermistor Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-washing-machine-te-code/
A Samsung Washing Machine displays a LE1 error code when a Water Level Sensor Error has been detected by the internal electronic diagnostics. You can find more info here
https://appliancerepairinfo.com/samsung-washing-machine-le1-code/
If all of the water has been drained from the washer, check the hose to the water level sensor is not plugged. You can find information on the nd error code here
https://appliancerepairinfo.com/samsung-washing-machine-nd-code/
EVER LOOK ON THE BACK OF IT
Samsung Washing... | Answered on Dec 16, 2019
Contact Samsung directly to request it.
Samsung Washing... | Answered on Dec 03, 2019
How to Get Back Disappeared Data on Samsung
The best way to get back disappeared data on Samsung is using dr.fone - Recover (Android). It is specially designed for recovering deleted data from Android device without backup. The recoverable types of files including contacts, text messages, gallery, videos, call logs, calendars, documents, WhatsApp messages and more.
Not only data recovery, it has other functions like Android data backup & restore, recover data from broken Android device. It compatible with all Android models, such as, Samsung Galaxy S5/S6/S7/S8/S9, Note 4/5/8/9; Google Pixel, Huawei, LG, Lenovo, Motorola, ZTE, OPPO, Xiaomi, etc,.
LEARN MORE
Samsung Washing... | Answered on Dec 02, 2019
Samsung Dv5471agp 27" Front-load Gas Dryer Logo
2 questions posted
Top Samsung Washing Machines Experts
Paul
Eric Rotmil
Eric Rotmil
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Washing Machines
Most Popular Question
dv5471agp dryer will not stay running
  • Washing Machines
