This is a direct-drive washer and the part that usually leaks is pump which is directly coupled to the rear spline o the drive motor. The cabinet is removed for access to the machine parts instead of the back panel. You have to replace the pump if it is leaking.
Remove the screws securing the console to the rear of the machine then pull forward and up on the
console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab,
located in the middle, and pulling it up.
The cabinet is attached
to the rear of the washer by
two brass-colored
retaining clips. Insert a flat blade screwdriver into the turned-up edge
of the clip, located on both sides, and then pry back to release the
clip from the slot in the cabinet.
Open and hold the lid while grabbing
the cabinet front opening then tilt the top of the cabinet toward you by
pulling the cabinet away from the base. This releases the front and
back slots of the cabinet from the tabs in the front and back of the
base. Using the side of your leg and/or body as a support for the front
of the cabinet, carefully lift up and set the cabinet aside.
Pry the clips off
securing the pump to the motor and remove the pump.
