I hope this information may help.
copy n paste
http://www.partselect.com/MultiModels.aspx?ModelNum=RAS6233KQ&searchTerm=img_FOU23FEA&RefineSearch=0&imgMfg=Whirlpool&Page=4
1) Unplugged electrical cord
2) Removed hot/cold water hoses
3) Took drain hose from laundry room recepatcle
4) Moved washing machine to area where I could lay it down on its back (very important for easy fix)
5) Found (easy accessible in my case) water pump with an inlet and outlet water hose held on with spring clamps.
6) Removed each of the two clamps with pliers and each hose by twisting loose
7) Remove two metal clips holding pump to motor housing
8) Slide pump off shaft - removal is finished!
9) Reversed process for installation, making sure to gently align pump housing when the pump is aligned with the shaft
[probably took less than 15 minutes
"Was this helpful?" YOUR RATEING is very important.thank you
