20 Most Recent Acer Extensa 367D Notebook Questions & Answers
How i can put built in webcam on desktop of Toshiba laplop
What software does the internal webcam use? CyberLink? Open CyberLink.
1/19/2013 2:38:06 PM • Acer Extensa... • Answered on Jan 19, 2013
Acer Crystal Eye webcam question
If you are using Windows you can use windows Movie Maker to record and Save videos
7/26/2009 9:28:45 AM • Acer Extensa... • Answered on Jul 26, 2009
0answers
0answers
Acer laptop/
Be the first to answer 7/25/2009 9:47:42 AM • Acer Extensa... • Posted on Jul 25, 2009Be the first to answer
Can't find a replacement battery
What is the model#, you have this listed under extensa 367d,
which is very old and does not even have xp on it.
4/23/2009 12:13:30 AM • Acer Extensa... • Answered on Apr 23, 2009
2answers
Acer cystal eye webcam
hi that would be simple if you find the folder in which the web cam icon is located right click on the icon scroll down to send another window should open up on the side then click on desktop(shortcut) this should put the icon as a short cut on the desk top.
NB:
the icon that you right click on must be the icon that acesses & activates the crystal eye web cam.
hope this solves your problem.
2/3/2009 6:48:42 AM • Acer Extensa... • Answered on Feb 03, 2009
2answers
Acer extensa 5620-6830. I am
I'm assuming you are trying to place the sd memory chip from your camera into the machine. If the machine has an sd slot, it will be in the front just to the left of the three ports or jacks for headphone, mic, etc... If it doesn't the you will need either a usb cable to attach your camera or an sd card reader that plugs into the usb port. You should be able to get either of these at the same place you got the camera.
8/4/2008 5:55:35 PM • Acer Extensa... • Answered on Aug 04, 2008
Crystal eye webcam how to use
hi, if its a built in cam , then the driver disk will take care nof it, now for chatting, u just need to open the chat applet, there you can find or go to "My Web Cam" that doed not need any software for video chat, most of the chatt applets are smart to locate your system web cam.. let me know
6/18/2008 5:07:03 PM • Acer Extensa... • Answered on Jun 18, 2008
2answers
Acer extensa 4210
reinstall the drivers, or go to your adminstrative tools in the control pannel and then computer managment, and then services and applications, inside you will find a list on services on your computer, find you cam and check its settings, you can also go to control pannel, sysytem, hardware and find the cam click on it, it should tell you if it is running correctly, you can also reinstall, the drivers from there
2/2/2008 4:19:10 PM • Acer Extensa... • Answered on Feb 02, 2008
Re: Bringing new life to Accient Acer Laptop (AAL) Extensa-367D
bios updete can do pto alimit it cannot convert 1.1 usb to 2 or support more memory . contact any service cenetr to get hel[ful advice and bios update
12/22/2007 7:26:12 AM • Acer Extensa... • Answered on Dec 22, 2007
Compaq V6608 no display after powering on
if its anew one u have full warranty serive from compaq . just go to any compaq service center with proof of purchase
12/22/2007 7:22:52 AM • Acer Extensa... • Answered on Dec 22, 2007
Internet explorer
Hi
It seems that your computer is infected with a spyware. I will give you some steps to try and resolve this.
Step - ( This will remove spy wares from the computer )
Open this link and download Free superantispyware
http://www.superantispyware.com/
Scan your computer with this and clean it.
If it does not let you download this, you need to try this in the "Safe mode with Networking"
Step to go to "Safe mode with Networking"
Turn off the computer. As soon as you turn it on start tapping the key "F8" untill you get a black screen with options of "Safe mode" and "Safe mode with Networking", select the second one and than log on to the computer.
Your display will be big and distorted in safe mode, dont worry as its a diagnostics mode.
Once downloaded the software you might need to rung the software in normal mode as sometimes this software does not work in the safe mode.
To get back to the normal mode. Simply restart your computer.
Hope this should take care of your issue.
Sammy
11/28/2007 3:41:54 PM • Acer Extensa... • Answered on Nov 28, 2007
2answers
Wont let me type in internet addresses- only accepts numbers
My best guess with the limited info given is that your settings on your computer are somehow not right. My best guess is your IP address is not correct. When you right click on my network places and go to properties you should see a list of connections. Double click on the one you believe is your internet. Click on the support tab and at the top it should say next to address type "assigned by dhcp" not "manually assigned". Hope this helps.
11/22/2007 10:41:13 PM • Acer Extensa... • Answered on Nov 22, 2007
Wont go to websites when Itype words- only accepts numbers
Open Internet Explorer, under the tools tab, select "Internet options". Once there, select the "Connections" tab. At the top you will see, "To setup and Internet connection, click "Setup", click on "Setup", once there, click "next", On the next page, make sure "connect to the internet" is selected and click next. On the next page click, "Setup my connection manually", click next. On the next page select(Make sure it reads exactly as follows), "Connect using a broadband connection that is always on", click next. On the next page, click "finish". That should do it.
11/19/2007 10:05:05 AM • Acer Extensa... • Answered on Nov 19, 2007
How i can boot from usb
if you want to boot a computer from the usb you will have to go into the bios and set the boot media ( HD, CD, USB) so that the computer knows where to search for the os.
7/19/2015 10:44:43 AM • Acer Extensa... • Answered on Jul 19, 2015
Acer Extensa 367D Notebook Logo
20 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Extensa Acer
  • Extensa Acer
Most Popular Question
find replacement battery
  • Computers & Internet
