20 Most Recent Acer Aspire 1414 Notebook Questions & Answers
Cvirg1 playlub pogo member login
12-n05mcr1por4myahvp1p4tak3-2-0_2.png Pogo Support: 1-408-763-5761 pogo support number, contact pogo support, pogo customer support number, pogo technical support number, pogo technical support phone number, pogo tech support phone number, pogo customer service live chat, pogo tech support number, pogo technical support, pogo customer care, pogo support, pogo help, pogo, https://www.facebook.com/clubpogocustomersupport/ #pogo support number, #contact pogo support, #pogo customer support number, #pogo technical support number, #pogo technical support phone number, #pogo tech support phone number, #pogo customer service live chat, #pogo tech support number, #pogo support #pogo customer care #pogo technical support #pogo help #pogo tollfree number
4/18/2019 11:31:30 AM • Acer Aspire 1414... • Answered on Apr 18, 2019
Files have removed not deleted to a unknown location
There is no reason why this should happen when removing a program or software.
Have you tried a system restore?
It doesn't normally retrieve missing files but as it is files specifically related to a program it may work.
Backup everything you want first, e.g copy my documents etc to an external drive
Start --> All programs --> Accessories --> System Tools --> System Restore
Click Restore my computer to an earlier date
Select a date in bold before the date when you removed the software
Click Next , next
Leave the pc to restore, power plugged in
You can always undo this restore later
If problems, please post results and I will help
Error messages etc.
Thanks
7/14/2015 4:39:11 AM • Acer Aspire 1414... • Answered on Jul 14, 2015
What grafic card
its what runs your screen with out on you will see nothing on your screen and it wont start up.
4/5/2015 7:27:58 PM • Acer Aspire 1414... • Answered on Apr 05, 2015
Acer aspire 1414 drivers
www.acer.com then type in, under" support and drivers" the model number.
3/1/2015 3:49:34 PM • Acer Aspire 1414... • Answered on Mar 01, 2015
How do i unlock an acer aspire one without a disk
You can't !!!
7/26/2014 12:56:25 AM • Acer Aspire 1414... • Answered on Jul 26, 2014
Malwarebytes
run a security program avg/ norton / should fix it
10/12/2012 2:26:29 PM • Acer Aspire 1414... • Answered on Oct 12, 2012
2answers
Acer Aspire On Netbook - lost wireless connectivity completely
Relax.. check all your drivers in device manager:
Vista- type device manager at startup
XP- right-click my computer -> hardware -> device manager
Make sure all the drivers is ok with no question marks or errors, if it does, reinstall your drivers from your driver CD.
8/16/2012 5:37:43 AM • Acer Aspire 1414... • Answered on Aug 16, 2012
I have an Acer Laptop and it has developed a band down the bottom of the screen from left to right of stripped colors about 1.5 inches high.How can I remove it??
There is no way to remove the colour bands, the only option is to replace the screen, go to www.ebay.com Type make and model of laptop, refine search to screen, this will give a idea on pricing.
6/13/2012 8:37:01 PM • Acer Aspire 1414... • Answered on Jun 13, 2012
Www.assistenciatecnicasansung.com
No Speeka English??
4/26/2012 12:32:30 AM • Acer Aspire 1414... • Answered on Apr 26, 2012
How do i find the hdd password in an acer
contact Acer support if you are the owner of the laptop and they can get you the master password.
2/8/2012 1:55:00 PM • Acer Aspire 1414... • Answered on Feb 08, 2012
Where is the wireleass internet
To enable the wireless, there is either a slider or a button on the front bezel. See this link:
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire1300/Aspire1300faq44.shtml
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
6/27/2011 11:43:35 PM • Acer Aspire 1414... • Answered on Jun 27, 2011
How to restore an Acer 1414 to factory settings, I
When you insert the (WINDOWS) disk, restart the computer and make sure you boot from the CD or DVD, not the hard drive. After it installs and asks if you agree with licensing, you should see 2 options for installing windows. Usually the 1st option says (RECOMMENDED) but in order for a 'clean' install you'll need to check the 2nd box that says ADVANCED. This is the option that allows you to actually restore it back to the way it was. The hard drive will have to be formatted which will clean out your files *** MAKE SURE THAT IS WHAT YOU REALLY WANT*** Those files will be gone for good. I also recommend getting on Youtube and search 'HOW TO FORMAT AND DO A CLEAN INSTALL OF WINDOWS' There are several excellent tutorials that will walk you right through it. It makes it easier if you can actually see what steps they are taking on their computer. I hope this helps! Good luck!
5/1/2010 4:28:59 AM • Acer Aspire 1414... • Answered on May 01, 2010
Looking for a dvd.cd unit for an aspire 1414.
uite unul http://www.cel.ro/unitati-optice/dvd-writer-samsung-sn_t083a-black-bulk-l/
3/15/2010 4:17:23 PM • Acer Aspire 1414... • Answered on Mar 15, 2010
Acer Aspire (1414) screen stays black when started
It's look like your laptop have a problem called "NO POST".
motherboard, cpu or memory can cause this problem.
To diagnose it, reseat your memory first and after that turn it on.
if it still no post.
use only 1 memory and turn it on, if still same,
Try to move your memory and seated to different slot and turn it on. if it still same, it's mean your motherboard/cpu is bad.
good luck
7/14/2008 5:57:49 AM • Acer Aspire 1414... • Answered on Jul 14, 2008
Screen stays black
Try using a different monitor if you have one available, or disconnect the monitor from the computer and then turn it on. If you see a logo or color bar or message saying no signal, then your monitor is OK and you should take a look at your video card.
If you suspect your video card, there is very little you can do with a no video situation. but one thing you can do is to remove the video card completely and wait for a few minutes. then put it back in and try to start your computer. This is just in case you have corrupted video memory keeping it from functioning. otherwise, replace the card.
In the case that your video is built into you computer, buy a new card and disable the onboard video in the BIOS. That will take some browsing in the BIOS setup, but it shold be fairly easy to find. once it is disabled, the new card will be able to function and you should be ok from there. Otherwise, it's motherboard replacement time.
7/11/2008 7:51:41 AM • Acer Aspire 1414... • Answered on Jul 11, 2008
Acer Blinks orange but doesnt work
you should reinstall your graphics or video card
otherwise you have to change your graphics card
1/24/2008 9:10:50 PM • Acer Aspire 1414... • Answered on Jan 24, 2008
Display problems
Check your desktop settings are'nt at 256 colours and also go to your graphics display in system properties and check if the correct driver is loaded. To double check driver go to Start>Run, then type 'dxdiag' then press Enter, for a sound and video diagnosis. IF all seems well possible notebook display fault.
12/22/2006 4:42:46 AM • Acer Aspire 1414... • Answered on Dec 22, 2006
Acer Aspire 1414 Notebook Logo
27 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
unlock acer aspire one without password
  • Computers & Internet
