20 Most Recent
Electrolux Washer/Dryer Laundry Pedestal with Storage Drawer - Island White EPWD15IW Questions & Answers
How do I remove a pedestal drawer on and electrolux dryer
Hello friend, thanks for your inquiry!
I have researched that information for you and was unable to locate steps on how to remove the drawer from your pedestal. I would suggest seeking assistance from a professional for proper removal of the drawer. Hopefully this helps. -Matt
My Electrolux dryer is throwing the code ehi
That is not a standard code. You won't find it on the Electrolux site. I can infer nothing from that. You can either try the general troubleshooting tips for Electrolux dryers OR try to contact Electrolux customer support. Since I have no access to whatever this code means, I can't assess the problem. Here is a troubleshooting video for Electrolux dryers:
https://www.youtube.com/watch?v=5dDqrB3nk2s
Electrolux Dryer screen went blank
I am not sure what your Dryer model is or its age but it could well be that there is a plug loose on the main control board or some fault on the wiring inside the top behind the display panel.You could check to see if this is the case but make sure the mains power is off first,remove the top lid and check,or It would be best to get in touch with Electrolux to see if a repair is covered under the Warranty.
Hope this helps.
Good luck.
What does e62 mean on an Electrolux clothes dryer
This error code indicates the water is overheating during the wash cycle. The first thing to check is if the water inlet hose is connected to the cold outlet and not the hot one. If the hose is properly connected, the temperature sensor will need to be checked and if faulty, replaced.
What is an e64 error code on electrolux dryer ewmed70jss?
Good Afternoon Friend,
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
