20 Most Recent
Acer ScanPrisa 640U Flatbed Scanner Questions & Answers
Looking for a driver for the Scanprisa 640u for Vista
1) Turn off User Account Control (UAC)
In Win vista Go to:
- Control Panel - User Accounts
a) Click - "Turn user account control on or off"
b) Untick - "Use user account control to help
protect your computer"
Then:
2) Go to driverguide.com and download xp driver for the scanner.
3) Find the setup.exe file in the driver install folder
4) Right click on the file
5) Choose properties
6) Click the Compatibility Tab
7) Tick "Run this program in compatibility mode for" tab
8) Choose "Win Xp Sp2" or the operating system you are using
9) Click "Apply" then "OK"
10) Run "Setup.exe" file
NOTE:
This procedure may be used to run other programs that may have compatibility problems.
How to install without cd
first of fall you download mirascan 3424 and then inistall it correctly and then go your control panel click on a add scanner icon add a scanner ofter that you download photofilter and inistall it finish
Necesito los controladores para un Acer ScanPrisa
Estos sirven para win7, los he probado en x86, no se si funcionen en x64:
http://driverscollection.com/?file_id=19052le da en download file, descomprime e instala setup.exe (es multilenguaje) y reinicia y listo.
Los controladores se instalan bien, pero no creo que le funcionen los programas que instala (muy viejos), le recomiendo que use el ABBYY finereader (muy bueno) para manejar los escaneos, para el OCR (convertir imagen a texto) o escanear imágenes con Photoshop.
Espero que le sirvan.
