20 Most Recent Zanussi FS1255S Front Load Washer Questions & Answers
How to clean it
You could purchase front loader washing machine cleaning chemical or soap. My experience with cleaning chemical and soap was to just masking smell, not fixing the problem. I did a few search and came out with using vinegar, baking powder and bleach is most effective way to clean and get smell out of washing machine. ie run cleaning cycle with 1 or 2 cup of vinegar, let it run for 20 ~ 30 minutes and pause for 30 minutes (it help break it up) let resume and finish cycle. Run cleaning cycle again with baking powder. If your machine don't have cleaning cycle use hot water and heavy load setting. Hope this help you.
6/13/2017 5:59:28 AM • Zanussi FS1255S... • Answered on Jun 13, 2017
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
5/1/2014 1:26:07 PM • Zanussi FS1255S... • Answered on May 01, 2014
Hi we are trying to fit
hi providing you have the right belt. run the belt over the pulley until its tight (it will only go half way round and feel impossible to get on but just run it on like you would cycle chain it takes some effort but once the belt starts to stretch you will find it will go on. just brute force will do it. good luck
11/15/2010 10:06:53 PM • Zanussi FS1255S... • Answered on Nov 15, 2010
My zanussi aquacycle makes a grumbling sound from
Sounds like the pump or filter is blocked, you need to check for blockage, if no blockage, then you need to fit a new pump.
8/6/2010 8:23:19 PM • Zanussi FS1255S... • Answered on Aug 06, 2010
Will not drain
hello have you cleaned the filter out at the front of the washer if ok then you may have a blocked pump or a kint drain hose
regards
shaun
2/20/2010 1:06:01 PM • Zanussi FS1255S... • Answered on Feb 20, 2010
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
2/17/2010 7:23:42 PM • Zanussi FS1255S... • Answered on Feb 17, 2010
MY ELECTRIC TRIPPED AN SINCE THEN MY WASHING
Hello there:
This clicking that you a re hearing is either the water solinod valve that is making this noise or the start switch timer that is doing this what you can try to do us to unplug the machine for 30 to 60 minutes then plug it back in and see if the clicking goes away if not you may have to have a certified technician do a full inspection of the unit make the repairs needed on the unit if you have a warranty with this unit you may be able to use it ok?
hope this is very helpful for you
Best regards Michael
12/18/2009 6:00:34 PM • Zanussi FS1255S... • Answered on Dec 18, 2009
Wont spin on a full load
check motor brushes.
10/26/2009 10:46:09 AM • Zanussi FS1255S... • Answered on Oct 26, 2009
WASHING MACHINE
Unless you can hear it catching as the drum is going round I would leave well alone, it will probably just get lodged near the heater and not cause any problem.
If the m/c has a removable rear panel then you can get access into the drum by removing the sump hose fastened onto the bottom of the drum. you might find it stuck there.
If no removable panel, then it is a strip down job, Not recommended, unless you know what you are doing.
12/13/2008 6:06:29 PM • Zanussi FS1255S... • Answered on Dec 13, 2008
Drive belt replacement.
If there is no rear access panel, then it is normally a cabinet off job, but it can be done from the top,
Lean the m/c towards you and with a bit of manipulation, you can actually fit the belt this way, it is awkward, but can be done.
12/12/2008 10:34:37 PM • Zanussi FS1255S... • Answered on Dec 12, 2008
HOW CAN I FIX BOSCH WFF 1401. NO POWER OR NOISE
Funny enough check the fuse again you could have installed a duff
make sure it's 13amp or on the fuse it will say 13A
DO that untill lights come on on the front or something.
Or if it comes to the worse and its under 8yrs old get it covered by domestic & genreal
Domestic & General is the UK's leading specialist provider of extended warranty cover for electrical domestic appliances and also provides repair protection for central heating systems
of cause don't be stupid and tell them that its broken at the time of taking out the cover, lol
get it covered leave it a week or so then report it to them as faulty
This is not an advertisement for them - and i don't make anything out of you using the link above it is NOT a affiliate link
go 4 it
3/7/2008 12:00:13 PM • Zanussi FS1255S... • Answered on Mar 07, 2008
Washing Machine
buy a new one with three year warranty or see a washing machine technition
11/24/2007 2:49:34 PM • Zanussi FS1255S... • Answered on Nov 24, 2007
Starts and then ends after about 1 min without doing anything
wire off the circulating pump or faulty door switch if you gis a bell on 01132570737 we can go through it with u we do a lot of work with zanussi washers and are willing to help
7/17/2007 5:00:20 PM • Zanussi FS1255S... • Answered on Jul 17, 2007
How to fit a door seal on a Zanussi FJ 1295
this is a faily easy task essential to lubricate the seal with washing-up fluid in the slot which goes on the tub. enter the lip of the tub into the slot on the seal and work round in both directions forcing seal on with thumbs. the spring goes into a groove so as to keep it in position on the tub. then similiarly, put the seal on the cabinet and follow up with the plastic ring
3/26/2007 8:14:33 PM • Zanussi FS1255S... • Answered on Mar 26, 2007
Need dimension of Zanussi Aqua cycle 400
1/4/2024 9:07:00 PM • Zanussi Washing... • Answered on Jan 04, 2024
Zanussi FS1255S Front Load Washer Logo
32 questions posted
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Zanussi Washing Machines
Most Popular Question
will not drain
  • Washing Machines
