20 Most Recent
ASUS P4P800S-X (610839118175) Motherboard Questions & Answers
Every time my processor is
Dear May be your processor HEAT gel is out of order or HEAT SINK have some problem, or other ways you have problem in your BIOS Processor Fan Settings.
Please Also Check bios Update from its original website.
Save not cmos on mainboard
ASUS CrashFree BIOS2
The CrashFree BIOS 2 feature now includes the BIOS auto-recovery function in a support CD.
Users can reboot their system through the support CD when a bootable disk is not available, and go through the simple BIOS auto-recovery process. ASUS motherboards now enable users to enjoy this protection feature without the need to pay for an optional R
C.P.R.(CPU Parameter Recall)
When the system hangs due to overclocking failure, there is no need to open the case to clear CMOS data. Just simply restart the system, the BIOS would show the previous setting and then users can amend the CPU setting again.
ASUS EZ Flash
With ASUS EZ Flash, you can update BIOS before entering operating system. No more DOS-based flash utility and bootable diskette required.
hope this helps you
Asus P4P800S-X IS RUNNING LCD SCREEN IS BLACK
First thing is check the monitor by replacing it with any working monitor. If that does not work remove the Graphics card and do the same. The problem will be either in the Graphics card or the monitor....sodeep
Won't start
Try resetting the bios. Have seen this problem with many pc's.
My pc don.t start normaly after i close it for a long time
You will have to go into more detail but if your saying it won't power up without a message that requires you to go into BIOS before restarting then your motherboard battery is bad and needs replacing. I've installed 2 ASUS motherboards and both had weak or bad batteries.
Cant run 3E GHz 800 FSB L2 cache 1MB cpu on a ASUS P4P800s-x
here are the specs.
CPU FSB DDR DIMM Type Memory Frq.
800Mhz PC3200/PC2700/PC2100 400/333/266 Mhz
533Mhz PC2700/PC2100 333/266 Mhz
400Mhz PC2100 266 Mhz
the CPC and the moemories meets these spec. then you shouldn't have problem.
since you didn't spec the meories. I am assuming that the meories are within specs.
but, from what you say about, I suspect the memories is not up to part. looks like the meories are in PC 2100 range.
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
