20 Most Recent
ASUS P5RD1-V Motherboard Questions & Answers
It starts, en then shuts down
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
P5RD1-V BOOT PROBLEM
The CMOS, which stands for complementary metal-oxide semiconductor, is
the hardware component of a computer that supports the BIOS, or basic
input output system. The two terms are often used interchangeably, and
the two technologies work together to perform the same basic function.
They maintain the low-level settings on a computer, letting the
computer know, even before the computer's operating system starts, what
kinds of hardware the computer has available, such as hard drives and
video display adapters. A special battery located on the computer's
motherboard powers the CMOS. To reset the CMOS on a Dell computer,
briefly remove and then replace the battery
- Turn off the
computer. Disconnect all cables and detach all devices, including USB
devices, from the computer. Press and hold the computer's power button
for 10 seconds after it has been unplugged. This grounds the system
board.
Step 2
Remove
the computer cover. All Dell systems have a cover panel on the chassis
that you can remove so that you can access the system's motherboard and
internal components. For some Dell computer lines, such as OptiPlex,
the computer cover is held in place by a release latch located on the
back of the computer. Pull the latch to release the cover and then
slide the over up and away. Other lines, such as Dimension, have large,
slotted thumbscrews. Turn the screws counter-clockwise until they
disengage from the chassis, the slide the cover off the computer. Dell
computers often ship with the computer's user guide in CD form or with
the guide pre-loaded on the system's hard drive. You can locate the
instructions for removing the cover from your particular system in the
user guide.
Step 3
Locate
the CMOS battery on the system's motherboard. CMOS batteries range in
size from size and thickness from about the size of a nickel to about
the size of a quarter. The CMOS battery will generally be labeled CMOS
on the motherboard and will be the only battery openly exposed on the
motherboard.
Step 4
Remove
the CMOS battery by prying it gently up out of its socket. The sockets
are specifically designed to allow the battery to be replaced.
Step 5
Wait
30 seconds, and then replace the battery in its socket. This will reset
the CMOS. Replace the computer cover to complete the process.
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem:
1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in.
2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable).
3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues.
4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations.
5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors.
6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable.
7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility.
8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement.
Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed.
Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy.
The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways.
Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue.
Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month.
Google Chrome Download - Download Google Chrome
google.comhttps://www.google.com
Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now
Get a new and fast web browser. Download Chrome and start browsing.
