20 Most Recent ASUS P4P800SE Motherboard Questions & Answers
0answers
0answers
WHEN I POWER UP ON
HI
it is a SMPS problem. SMPS is the main power supply it is also known as smart module power supply..
if you want to check try this link
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
9/5/2011 8:16:18 AM • ASUS P4P800SE... • Answered on Sep 05, 2011
When i download videos from the internet it cannot
Hi, here is the driver site for your mainboard:
http://www.asus.com/Motherboards/Intel_Socket_478/P4P800_SE/#download
You may have to find the driver for the screencard elsewhere.
Look in the controlpanel in the device settings under vga.
You may need these to also:
http://www.java.com/en/download/
http://get.adobe.com/flashplayer/
Try also to run windows update
It will maybe find the software for you.
Hope this will help you.
8/15/2011 1:01:37 PM • ASUS P4P800SE... • Answered on Aug 15, 2011
Video cannot be played, what
You need a graphics card for this motherboard, it does not have "onboard" graphics.
8/14/2011 1:03:23 PM • ASUS P4P800SE... • Answered on Aug 14, 2011
2answers
Hi, i connected an sata
The boards BIOS should not reference the partitions at all as this is done by software (ie OS) not the bios other than to identify the drive find its active partition and run the bootstrap.
It may be that your bios needs a newer firmware to recognize the drive correctly, or you could try manually entering the Cylinders, Heads & Sectors like the good old days, but IMO a bios update would be the thing to do.
7/25/2011 10:15:16 AM • ASUS P4P800SE... • Answered on Jul 25, 2011
2answers
I accidentally erased my ASUS
You can reinstall the drivers again. Here it is for download:
http://drivers.softpedia.com/get/SOUND-CARD/Asus/Asus-Eee-PC-1005HA-Seashell-Netbook-Audio-Driver-51005841.shtml
Hope this helps!
Remember to Thumb me Up lots for all the hard work! :D
~~Dayminner
6/3/2011 6:31:50 AM • ASUS P4P800SE... • Answered on Jun 03, 2011
Can u give me asus
You can download drivers from below website:
http://www.driverstock.com/ASUS-P4P800-SE-driver-download/6-9-10018-79886/index.html
click and download, then install, It will be work.
Thanks
4/13/2011 11:40:42 AM • ASUS P4P800SE... • Answered on Apr 13, 2011
2answers
Regarding P4P800SE the Power LED shown on page
plug in pin 1 and 3
4/1/2011 2:13:58 AM • ASUS P4P800SE... • Answered on Apr 01, 2011
USB NOT WORKING
It may be the operating system has not recognized all the ports, if you operating system is now ok, go to my computer>properties>hardware>device manager, and look to bottom of the list to USB Controller right click on them, and Uninstall all controllers and restart pc and see if all the ports are recognized and installed automatically.
If you need more information, reply me soon.
Thanks
2/20/2011 5:11:57 PM • ASUS P4P800SE... • Answered on Feb 20, 2011
2answers
What is the limit of the memory of the asus p4p800
4 gb
2/19/2011 9:53:25 AM • ASUS P4P800SE... • Answered on Feb 19, 2011
Hello, What is the maximum capacity (in Gigabyte)
The max HDD capacity on this motherboard is 500 GB
Regards
2/14/2011 8:57:49 PM • ASUS P4P800SE... • Answered on Feb 14, 2011
LA P4P8OOSE FUNZIONA A
Could you describe the problem?
1/22/2011 4:39:25 PM • ASUS P4P800SE... • Answered on Jan 22, 2011
Shut down my PC, unplugged it, moved it to new
Remove cmos battery and then replace it after 3 mins or so,
Try rebooting
If no luck, remove ram modules one at a time and retest
unplug all but hdd and power connector to mobo, cpu and hard drive and retest.
failing that, could be a surge of electricity has damaged your mobo
1/11/2011 12:35:50 AM • ASUS P4P800SE... • Answered on Jan 11, 2011
What is the problem if
May be battery has been faulty.You can check it with another battery.
1/5/2011 7:26:21 AM • ASUS P4P800SE... • Answered on Jan 05, 2011
Hi I have a problem
U JUST NID 1 CABLE FOR THE LAN CARD TO THE INTERNET MODEM.....
PUT YOUR LAN CARD IN THE PCI SLOT... AND INSTALL THE DRIVER OF THE LAN CARD...
10/22/2010 8:48:28 AM • ASUS P4P800SE... • Answered on Oct 22, 2010
My asus p4 800 se
Normal 0
You can download the drivers from ASUS WEB site. Select your model motherboard/computer/laptop, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Please click on this link to their WEB support site : -
http://support.asus.com/download/download.aspx?SLanguage=en-us
10/10/2010 9:05:35 AM • ASUS P4P800SE... • Answered on Oct 10, 2010
How do i change from 32 bit to 64 bit on a asus
The only way to Upgrade from 32 bit to 64 bit is to buy a 64 bit MOBO and replace it with the 32 bit MOBO.
10/6/2010 7:56:47 PM • ASUS P4P800SE... • Answered on Oct 06, 2010
How do I wire up my Asus p4p800 se motheboard with
no need to modify anything just plug in the 20 pin mb power connector the 4 pin cpu connector and your HDD's and disc drives power the same as your old setup and your good to go. mb's are designed to handle a broad range of wattages, if your not sure what plugs go where take a few photos before you begin unplugging or draw a simple diagram
8/26/2010 3:33:10 PM • ASUS P4P800SE... • Answered on Aug 26, 2010
ASUS P4P800SE Motherboard Logo
52 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
when power up
  • Computers & Internet
