20 Most Recent
Zanussi 23 in. ZKT641H Electric Cooktop Questions & Answers
My Zanussi Induction cooker model ZKT 621LX is not
Hello Horus,
The child-lock has been activated - probably accidentally, but someone may think you're not safe to use it. The de-activate the child lock . . .
1. Switch the cooktop on so all zone show "L"
2. Press both the + sign for the right-front zone and the - sign simultaneously. All four zones will show "0" with flashing decimal points.
3. Press the - sign again. The cooktop will switch off.
You can now switch the cooktop on and use it normally again.
Hope this helps. If you have any difficulty de-activating the child-lock or need further assistance, please let me know.
Regards,
BElectric.
Have a baumatic ceramic hob displayin letter 'L'
Got the same problem, and remembered I've kept the manual book
L means locked. I dont know how Ive managed to do this as well
Anyway it says:
Cancelling the key lock
After switching ON the control the child safety feature can be deactivated. Here it is necessary to simultaneously operate the front right cooking-zone-select-key and the MINUS-key and then operate the MINUS-key alone. If all steps hae been carried out in the right order within 10seconds the key lock gets cancelled and the control is OFF. Otherwise the input will be considered incomplete, the control remains locked and switches-OFF after 20 seconds.
After a renewed switching-ON/OFF key all displays show 0", the display dots are blinking and the control is ready for ooking. If a cooking zone is "hot", "H" will be displayed instead of the static 0".
Followed their instructions & still not worked. ,I am still confused and baffled after these instructions........................
Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
I need to know the
Sorry to read about your problem, I hope this helps you out.
you dont need a wiring diagram, the part should be a direct replacement.. wire for wire..
if not you got the wrong part
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
What's the best way to clean the Zanussi stovetop?
There is a product called cerama bright (Not sure of the spelling). Specifically formulated for exactly this type of cleaning. Availible through just about anywhere (Home Depot, Lowes, Wallmart, etc) Good luck!
