20 Most Recent Canon iRC3100 Printer Questions & Answers
My photocopy of canon ir3100f the give massage
Wich code?
Here is examples:
E000 Insufficient temperature rise of the fixing unit at power-on
E001 Abnormality of the fixing unit
E002 Insufficient temperature rise of the fixing unit
E003 Low temperature of the fixing unit after standby
E004 Error of the protection circuit in the fixing unit
E006 Connection error of the fixing unit
E008 Life expectancy of the fixing roller
E010 Main motor error
E012 Drum motor error
E013 ITB waste toner full error
E014 Fixing motor error
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
E021 Developing rotary error
E026 Toner empty error
E032 The counter of the NE controller fails to operate.
E045 OHP sensor error
E067 High voltage-related error
E070 ITB HP detection error
E100 BD error
E110 Operation error of the laser scanner motor
E202 CIS unit HP detection error
E225 CIS light quantity error
E227 Power supply error in the reader unit
E243 Control panel unit error
E248 Backup memory error
E315 Abnormality of image data
E351 Main controller PCB error
E400 Feeder communication error
E490 Model error
E500 Finisher communication error
E503 *** Finisher internal communication error
E505 Finisher backup memory error
E514 *** Stack delivery error / **** End assist motor error
E519 **** Gear change motor error
E530 *** Rear alignment error / **** Front alignment error
E531 Staple error
E532 Staple unit shift error
E535 Swing error
E537 *** Front alignment error / **** Rear alignment error
E540 *** Stack tray up/down error / **** Upper tray up/down error
E542 **** Lower tray up/down error
E577 *** Paddle error
E580 Stack tray up/down error
E584 **** Shutter unit error
E590 ***** Puncher motor error
E591 ***** Puncher dust sensor error
E592 ***** Puncher side registration sensor error
E593 ***** Puncher shift motor error
E5F0 **** Saddle paper positioning error
E5F1 **** Saddle paper folder error
E5F2 **** Saddle guide error
E5F3 **** Saddle alignment error
E5F4 **** Saddle rear side staple error
E5F5 **** Saddle front side staple error
E5F6 **** Saddle paper push-on error
E5F8 **** Saddle connector error
E5F9 **** Saddle switch error
E601 Abnormality of image memory
E602 Hard disk error
E604 The image memory (SDRAM) is faulty/insufficient
E609 * Abnormal low temperature of the hard disk
E610 ** Failure in the hard disk cryptographic key
E674 FAX board communication error
E677 Abnormality of the external controller
E710 IPC initialization error
E711 IPC communication error
E712 Communication error between the ADF and the reader
E713 Communication error between the finisher and the printer
E717 Communication error with the NE controller
E719 Communication error with the coin vender/card reader
E730 PDL error
E731 UFR PCB error
E732 Reader communication error
E733 Printer communication error
E740 Abnormality of the Ethernet board
E743 DDI communication error
E744 Language file/BootROM error
E745 * Token ring board error
E746 * Option board error
E747 Main controller PCB error (Image processing ASIC or memory control/communication control
ASIC)
E748 ** Main controller PCB error
E749 ** Restart in accordance with a change of the product configuration
E803 Door close error
E804 Controller fan error
E805 Fan error
11/14/2023 4:43:04 PM • Canon iRC3100... • Answered on Nov 14, 2023
3answers
How do I get a list of what the errror messages
I have error message E000537-0000 on the screen.
2/2/2018 6:07:22 AM • Canon iRC3100... • Answered on Feb 02, 2018
E00748-4000 error on canon irc3180 copier
Try this Board Cleaning & re-Positioning Procedure Works 98% of the time for this e748-4000 your model is in same family as those listed in pub or---------------------- Check or swap or replace the DDI-S Serial Cable before replacing any boards. If the cable is poorly connected or otherwise defective an error code of E748-4000 may be the result.
10/10/2017 9:30:44 AM • Canon iRC3100... • Answered on Oct 10, 2017
E000012-0001
Thread irc 3220 error e000012 0001 Your ITB unit (Intermediate Transfer Belt) may need changed. Try removing it first and rotating by hand. If it sticks, you are probably looking at a new unit. The link above is for the iRC3220 but Canon codes are generally all the same. You may find there's a tear in the belt and this is why it is not working properly.
4/13/2015 4:59:38 PM • Canon iRC3100... • Answered on Apr 13, 2015
Error Code E000013-0000 Solution
please replace the waste toner container.
10/30/2014 9:00:14 PM • Canon iRC3100... • Answered on Oct 30, 2014
Ir c4080i E000604-1536 any one can help me to solve this error code please?
upgrade the sdRam up to 1gb to solve that problem
6/23/2014 10:02:23 PM • Canon iRC3100... • Answered on Jun 23, 2014
E000100-0001 canon ir 5800
This error is related with the laser unit, probably malfunction in that section
6/6/2014 3:09:09 PM • Canon iRC3100... • Answered on Jun 06, 2014
0answers
0answers
IRC 3180
tonner is insufficient
3/17/2014 3:05:56 PM • Canon iRC3100... • Answered on Mar 17, 2014
Canon ir 5870 c showing the error code E000003 - 00051
Canon IR 5870c showing the error code E000061-0003 please tell me how to remove error E000061-0003
3/9/2014 6:30:38 AM • Canon iRC3100... • Answered on Mar 09, 2014
0answers
Error e602-0003
This is Hard disc error, before changing the hard disc ,first try to format it and re install new firmware by using service support tool, if you are not able to do it change the Hard disc, your problem will be solved.
1/27/2014 12:35:56 PM • Canon iRC3100... • Answered on Jan 27, 2014
Canon iRC3100 Printer Logo
246 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
photocopy canon ir3100f give massage
  • Office Equipment & Supplies
