20 Most Recent
Canon BJC 1000N InkJet Printer Questions & Answers
Showing Service error 5C00.
This shold work, wrote Printx:-
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in succession. Note: you are still holding the POWER button). The printer's carriage will "reset" or move momentarily.
If the above was properly performed the printer will enter the "Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp will alternate (change) color with each key press. Next press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
I want to dowmload the software for the bjc1000sp
it doesnt have a win 7 driver
http://www.canon.ca/inetCA/serviceDetail?m=load&id=3&sid=19&mid=0002027&type=S
but it does have a windows vista driver,,
keep the printer connected and restart your pc,, then go to windows update and install the optional updates (chances are win 7 will pull and use the vista driver)
Canon BJC 1000SP Printer suddenly refuses to print
Hi there
You can try see if this may do it.
Go to Start / Run and type in "services.msc" without quotation marks, then press Enter or click OK.
In the window that opens (Services) look for "Print Spooler" on the right
Right-click "Print Spooler" and select "Properties".
Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service".
Make sure the 2 text boxes underneath say "1" in them.
Click Ok until you are back at the Services window, close it and you're good to go.
Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
The Print spooler depends on the Remote Procedure Call (RPC) service. Is this service disabled? Go to services.msc look for RPC. Check state: Automatic
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Waste ink tank full
Ok try this may work
1: Remove Cartridge
2: Unplug the AC Power Cord
3: Hold down the RESUME button
4: Release RESUME after plugging in the AC Power cord.
5: Press the RESUME once within 5 seconds and release the RESUME .
6: Press and HOLD RESUME for two seconds or more and release it.
7: Press and HOLD RESUME for two seconds or more and release it.
8: Unplug AC Power Cord to set data.
Canon BJC-2000 BJC-2100 Serie
1: Remove the Cartridge
Printer
1: Remove Cartridge
Service error -5000
Hello there
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Printer cable
There are NO pins but on each side are 18 contact points. It takes a
parallel printer cable. Plug has long rectangular piece inside with 18
copper/brass contact points on either side. the plug has a wing on each
end that are held in place by the wire connectors on the printer.
Dave
Conon BJC-1000
reset the power, unplug the power cable (ac adapter) from the printer or the wall socket leave it turned off for 15 mins then reconnect it back. It will definitely work.
Frozen mouse
well the touchpad can be frozen for many resons, primary reasons could be.
1. the compter is hung in other words it needs to reeboot.
2. the touchpad has spoiled, if your laptop is under warranty please visit the nearest toshiba service center.
3.Yes, an external mouse would work but please check if you have a ps/2 port for regular mouses or otherwise please buy a wireless mouse they arent expensive now a days but very convineint.
Best of luck :-)
Have a nice day !!
Ples Help me
Canon download site:
http://software.canon-europe.com/products/0000393.asp
I really need it now
Hello you can find the official driver at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=329&modelid=7952
Option: Drivers / Software
The link will launch in a new window
