20 Most Recent
Canon BJC 4300 InkJet Printer Questions & Answers
Canon bjc-4300 error message no paper
You will need to clear the "print queue" of those failed print attempts.goto START--->Control Panel--->Printers and Faxes at the top, click on View, in the second section, choose -Tiles-.Locate your printer's Icon, and see if the number below the pic is greater than 0. If it IS, then double-click it, a new window will open. Click on the -Printer- drop-down list, choose "Cancel all Documents" (this can take up to a min.) If the docs do not clear after a min, then do it again. Once they're all gone close that window.Sometimes the plastic "guides" in a paper-tray, (which report the paper type to the printer,) become slightly out of place and report the absence of paper, though it really means -paper of the correct type-; because it thinks the wrong-sized paper is loaded. This can happen when a good-sized chunk of paper is dropped into that space and the paper pushes on the -guides-.Move the length, (if any,) and width paper guides away, then back to their proper positions and see if that helps.Tallon41
I can't find ink cartridges for it anywhere.
Take a look at my tip on cartridges it may save you a lot of time and money
http://www.fixya.com/support/r3845491-ink_cartridge
OR
Read on and see if any applies to you.
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
If you try to clean the contacts be VERY careful cleaning contacts and ONLY use isopropynol on a lint free bud or cloth.
Also be very gentle.
I have seen the contacts cleaned and cartridges ruined with other methods of cleaning.
Rubbing too hard can also cause a badly set chip to move making it inoprable.
I dont like full prices replacements either which is why I always provide the links
I usually reccomend that people take back any cartridge that does not work right from the get-go.
I dont know of anyone who has had a problem doing that be it a shop refill or otherwise.
No matter if I paid $1 or $100 for a cartrdige I would still expect it to work
Hope this gives you the information you need
Bob
EXMod
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Cannon BCJ-4300 has stopped printing/ new ink and
Sometimes the printhead itself gets clogged. You can remove it with the
green lever to the right of it. Take both cartridges out, take the
printhead alone and soak it in lukewarm water for an hour. Rinse when
done. You will likely see lots of black ink in the water that has been
softened and removed from the printhead. Blow excess water off or leave
it to dry. Put known good cartridges back in and you should be ready
to go. Done this many many times.
I have been using a Canon BJC4300 for years. Love
Sometimes the printhead itself gets clogged. You can remove it with the green lever to the right of it. Take both cartridges out, take the printhead alone and soak it in lukewarm water for an hour. Rinse when done. You will likely see lots of black ink in the water that has been softened and removed from the printhead. Blow excess water off or leave it to dry. Put known good cartridges back in and you should be ready to go. Done this many many times.
Have new inks but still want print,
Did you remove the seals from the cartridges???
Please double check this and then go into the printer program (in the control panel) and run the cleaning routine.
Thanks for your interest in FixYa.com
a
DON'T KNOW HOW TO TAKE INK CARTRIDGE OUT OF CANON
turn printer on then lift the lid after a few seconds the cartridges will come to rest in the middle of the lid opening then just lift the cartridge out by holding clip in and pull the cartridge up when you put the new carttridge in simply load it in then push down near the end where it says push hope this helps regards Jim
Canon bjc-4300 cartridge insists on staying in middleofprintfield
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Green light flashing
To pin it down to a hardware fault, you may need to remove the printer from the usb port, uninstall driver and re start pc.
Check your printer and faxes folder to make sur there are no other canon printers listed, if so delete.
Re install printer driver, then when prompted connect printer to a different usb port and see if windows recognises your printer and is installed ready to use.
Try again and if the same problem you know it's the printer thats faulty
Printer won't print
It always helps to replace with the correct brand as cheaper versions do fail, also if you had replaced it with a BC-20 from Canon, the supplier may replace it for you. It would be a good idea to trust the printer at this stage, try a Canon BC-20
Printer does not react to computer
You either have corrupt printer drivers or pc hardware issues. I would turn printer off. Unplug it and leave it off. Now uninstall it completely. Make a back up copy of your printer disc to eliminate it as a cause, and put aside. Now, on your pc run antivirus and antispyware (you should have these alredy!) I recomment avg free for both. Also run a registry repair progrsm like regcure (always do a restore poit save first, and make a backup copy of registry first beforehand. Sometimes registry repair can leasd to more issues and you have to go back to past settings. Now, reinstall printer with the backup disc, not the original and post back to let me know if this helped.
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them).
I suggest you clean the head during the printer on.. try to perform below steps per the manual
Cleaning the printer
Printing the test pages
Cleaning the print head
I assume you do not have the manual anymore (no DVD) i list down the step below
Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual
Cleanning printer
Make sure the printer is turned off before cleaning it. It is a good idea to
unplug the AC adapter
also.
Do not clean the exterior of the printer with volatile liquids such as thinners,
benzine, or any
spray-type or chemical cleaners; doing so will damage the surface of the
printer.
When cleaning the printer, avoid the area near the print head on the BJ
cartridge. Do not touch the print head. Ink may leak out and cause stains.
Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris
from the interior of the printer using a soft cloth moistened with water. Clean especially well
around the platen area. If the rollers become dirty, you can clean them using a small soft
brush.
Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges
and dust.
Do not use paper products (such as paper towels or tissues) to clean the inside
of the printer.
Printing the Test Pages
You can print these test pages to check the operation of your printer and your print quality.
Test A
This test prints a repeating pattern of characters.
Demonstration
This test prints a sample page describing the printer's features.
Printing the Test Page From Windows
You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to
print a self test, demonstration page, or a nozzle test pattern.
Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see
Automatically Feeding Paper starting on page 3-7).
Click on the Test option and then click on the Print button.
Printing the Test Pages Using the Operators Panel
To print a test page, make sure the printer is turned off and paper is loaded.
Press and hold the POWER button until you hear the number of beeps that
correspond to the test page you want to print.
Test Page Number of Beeps Pages Printed
Demonstration 1 Continuous Printing
Status Information 2 1 Page
Test A 3 Continuous Printing
Nozzle Test 4 1 Page
When you release the POWER button, the test page starts to print.
*All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print
will result in parts of the printoutbeing printed directly on the platen.
All self-test prints are printed in accordance with the current printing settings (font, printing
mode, etc.)
*Red- Information for technician not included in the user manual
Cleaning the Print Head
Your printer is equipped with a print head cleaning function to ensure constant high quality
printing.
Cleaning the Print Head From Windows
If you are using Windows, you can execute print head cleaning from the Control sheet in the
printer driver. Simply click on Clean Ink Head.
4300 Chapter 4 Page 6
Cleaning the Print Head Using the Operators Panel
If you want to clean the print head from the operator panel, follow these steps:
Make sure the
printer is turned
on.
Make sure the green POWER light is on.
Press and hold
the RESUME
button for at
least two
seconds until
the printer
beeps twice.
The POWER light will blink for several seconds while the print head is being
cleaned.
Perform the print head cleaning only when you encounter a print quality
problem. Unnecessary and repetitious cleaning will waste ink.
If you execute the print head cleaning while paper is manually loaded, the
printer will eject the paper and then perform the cleaning.
4300 Chapter 4 Page 7
