20 Most Recent
Canon 730i Laser Printer Questions & Answers
E004 error Canon 7301 Mfc
Here's a
link to your support site.
Error E004 is:
Faulty fuser, replace Fixing Assembly(RG5-5559-000)
Hope this info helps.
Reset toner cartridges
Sign on to Canon's website and download the instructions for changing the toner and resetting the page count.
Makes French police car sound every 2 minutes
it is trying to resend/receive something. NG means No Good - so the beep is an indicator of the missed-tranmission.
I suspect someone inadvertently setup a pop3 check interval and it cannot connect to the specified mail server.
Check by going to the Data Registration button (flip all the plastic covers over the button pad)
go to additional settings->3.Fax settings->1.user settings->8.Lan settings->Mail User Settings->
SMTP Server->4. check interval
It should say 000MIN
I bet it is set to 2MIN
Maurice
Error message E100. How
E100 Scanner unit failureCause: (1) Poor contact in the laser/scanner unit connectors(2) Defective laser/scanner unit(3) Poor contact in the ECU board connectors(4) Defective ECU boardSolutions: (1) Reconnect the BD board connerctor (J871), laser driver board(J801), and scanner motor connector (J851).(2) Replace the laser/scanner unit(3) Reconnect the ECU board connectors J913 and J914 correctly.(4) Replace the ECU board.http://www.wupload.com/file/211837258
How do i reset my
Just open the cover from where you are putting your toner cartridges and the printer will start self test and will reset from paper jam.After the printer dosn`t find any paper it will try to print your last task.
