20 Most Recent Canon imageCLASS D760 All-In-One Laser Printer Questions & Answers
What does supply rec. paper mean in the LCD display
Your machine is not feeding paper correctly. Check for any obstruction in the paper path
3/28/2015 12:39:33 AM • Canon imageCLASS... • Answered on Mar 28, 2015
Canon D660 Error Code E805 I read it was a bad
Which fan? There usually is one for the Fuser and one for the power supply. As for disassembly, you really need the Service Manual to take it apart correctly.
10/23/2013 1:34:49 AM • Canon imageCLASS... • Answered on Oct 23, 2013
0answers
0answers
Canon D760 print problem - print image
Duplicated images on pages is either the drum, or fusing/setting unit. Since this is an all in one unit, I am assuming the ink/toner cartridge includes the drum. I suggest replacing the fusing/fixing unit. (the hot part of the printer"
8/15/2012 7:45:21 PM • Canon imageCLASS... • Answered on Aug 15, 2012
Printer only printing white copies
HiTry cleaning the print head and see what happens.Thank you
5/30/2012 5:54:54 AM • Canon imageCLASS... • Answered on May 30, 2012
Paper comes out white. No text. Reports will
The document scanner has light bar which Canon calls the "Contact Image Scanner" FH7-7565-000. It is probably bad.
This unit is under the glass, so I'd recommend to get a service company to do this.
Whit 800-367-4836
www.iteminconline.com
6/7/2011 10:34:30 PM • Canon imageCLASS... • Answered on Jun 07, 2011
When a copy its made
You need to replace the drum unit.
3/19/2011 8:54:19 PM • Canon imageCLASS... • Answered on Mar 19, 2011
My print is canon D760 has piece a paper lock
Make sure the cassette is pushed in all the way and it has paper in it. Then go back and open and reclose everything you did before the jam.
2/15/2011 1:59:28 AM • Canon imageCLASS... • Answered on Feb 15, 2011
Where is the platen located
The platen is the part that covers the large original glass. That is why this glass is sometimes called the "platen glass". More commonly the glass is called the original glass because that is where you lay the original to be copied if you are not using the feeder.
Thank You for using Fixya.
1/10/2011 7:20:50 PM • Canon imageCLASS... • Answered on Jan 10, 2011
Paper jam is now clear ,still shows error light
If you reset the copier by open and close the top scanner, by moving it left and then right, and you still have a paper jam error on this model there are only 2 options one that there still a piece of paper holding the switch, 2nd option is that the switch is broken or out of place. If you remove the paper from the fuser, the left side of the machine, where it exit, your only option is to take the fuser unit out, and check the switch, recommended for technician only!!!
If you found the paper at the right side of the copier, take out the cartridge, lift up the metal plate on the bottom, swing it up and look for the paper.
Good luck.
12/2/2010 3:45:30 AM • Canon imageCLASS... • Answered on Dec 02, 2010
Sparks fly from cord connection (at the side of
probably the rubber encasing isnt completely covering wire and sparks come from electric current touching metal. have that checked out proffesionally repaired
11/30/2010 2:24:59 AM • Canon imageCLASS... • Answered on Nov 30, 2010
I have a Imageclass D760
as of now even microsoft is working towards a solution for the 64bit drivers as soon as it is available it will be posted on the microsoft site, you can also go ahead and describe the complete problem to them since they would be needing some more details with regrds to the printer in order to get a solution.
hope this helps
here is the link to a questionare which needs to be addressed with microsoft
http://www.microsoft.com/Windows/compatibility/windows-vista/Details.aspx?type=Hardware&p=Imageclass%20D760%2016ppm%20600x600dpi%20Printer%2fCopier&v=Canon&uid=D760&pf=2&pi=8&c=Printers%20%26%20Scanners&sc=Multifunction&os=32-bit&feedbackPage=suggest
10/10/2010 11:19:48 AM • Canon imageCLASS... • Answered on Oct 10, 2010
Canon imageCLASS D760 All-In-One Laser Printer Logo
97 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
imageCLASS Canon
  • imageCLASS Canon
Most Popular Question
canon d760 print problem print image
  • Office Equipment & Supplies
