20 Most Recent
Canon imageCLASS MF5770 All-In-One Laser Printer Questions & Answers
Set up my printer to work wirelessly with my laptop
Is your printer able to accept a USB ??
Purchase the wireless networking USB connector...Install the software onto your laptop and if your laptop has wireless connections already, it shoudl automatically pick up the printer. If not you need to also purchase a wireless card for your computer.
My Canon MF5770 suddenly quit working:
Do a hard reset and see if that restores normal operation. U might also resort to uninstalling and reinstalling the driver. If neither does the trick you have a sic puppy needing repair or replacement.
My canon mf5770 is copying double copies
Under your page set up you will find a box to select for two sided copies make sure it is not checked marked and when your preview of the document to be printed there is a box selecting two sided un mark it. make sure you have not selected sort it will be under finishing. and you may have a selection of save paper it will make it go to two sided. of course to save paper. There is a big push to save paper in our industry and machine have a ECO setting for saving our enviroment.
MF5770 ck paper size- change paper size
Go to the queue of print documents and continue deleting them until you get a message that reads no more in the queue. That will clear the error and then you should be able to resend with the correct paper size.
In our case the correct paper size was selected and received this error.
Canon mf 5770 problem : opening the mf toolbox
I have the same problem. You can't use Canon Toolbox 4.9x. It does not work. You will have to download and intall the x64 driver only from the Canon website for the MF5770.
Unpack the x64 driver and install it.
Go to the Start-menu and click on Units and Printers. Right-click with your mouse when hovering over the printer, then choose scan, fax or print.
We can only hope that Canon will solve the problem in the future, most likely not since MF5770 is an older Multifunction-machine.
