20 Most Recent
Canon imageCLASS MF5750 All-In-One Laser Printer Questions & Answers
Mf5750 adjusting waiting to scan
Hello,We are an authorized Canon Service Center and I can tell you 90% of the time the solution is simple. The machine needs to "acclimate" itself.Just unplug it.....wait a second or two....plug it back in. The next part is the hardest - you have to wait. DO NOT touch any buttons or mess with the machine during this waiting period..and I mean nothing. Sometimes the wait can be 15 minutes. But after that all is good to go. The Canon MF3110 series is very similar and we have set-up around 100 of these. ALL of them were like this. No big deal. Being that were are an authorized service center for this machine and you might need a part or something, you can find us easily by go to:
http://bopcanon.com/IMAGECLASSMF5750Series.aspxThanks :>)
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
Cleaning roller
lift the feeder open (as if you were going to copy off the glass)now look at the skinny glass to the left of the big glass you will see dirt there get some windex or alcohol on a rag or something and wipe it off if you do not have alcohol use cologne or something and get all the dirt off then try making a copy using the feeder problem solved guaranteed:)
Driver windows xp
How did U determine its Driver problem?Try this: 1. makesur printer software from cd installed properly and2. this printer is a default printer3. check cable connections fro P to cpu.4. check if settings ok.5 print test page.goodluck
How to i clean the drum - there is a mark every few inches when i print
If the mark is persistent on each page and repetitive with very precise spacing, you need to determine which roller it's coming from. It could be coming from the transfer roller, before the fuser, the fuser itself, or the fuser pressure roller. Measure the spacing distance of the mark(s), then measure the diameter of the 3 above mnetioned rollers, multiply by pi (3.14159265) and compare the results to determine exactly which roller is causing the issue, then replace that particular roller. Hopefully it's not the fuser as you'd be better-off replacing the fuser film (main fuser roller lining). The fuser and pressure roller are a pain to source, and run abou $65+ for the pressure roller, and about $90+ for the fuser, not to mention this 2 last rollers will take about 1-1.5 hours to replace. They are not hard to replace using common tools. Don't forget to locate the printer service manual over the internet first.
How to connect networking printer canon
Check your router status page for connected devices and then use an internet browser to connect to the assigned IP for your printer. From there you can configure the printer for your network. If you have issues, then perform a factory reset of the printer and then repeat the steps above, this will clear-out any previous network configuration that was setup on it, making it much easier to configure.
