20 Most Recent Canon CanoScan N670U Flatbed Scanner Questions & Answers
"Selected application is invalid error" What does this mean pls?
Hello! Please check the manual. Maybe you just need to update the scanner. https://manualsbrain.com/en/manuals/1795488/?page=10
10/20/2017 7:56:25 AM • Canon CanoScan... • Answered on Oct 20, 2017
Need a driver for a CanoScan N670U Scanner for Mac 10.5 OSX
Basically you should not scan through Photoshop but should use your scanning software as a stand-alone application
4/23/2017 12:24:11 PM • Canon CanoScan... • Answered on Apr 23, 2017
Driver Canoscan N670U for windows 7 64-bit
Free option to use CanoScan N670U wth Windows 7 64 bit VueScanner cost$ --> I am running Windows 7 64bit and was able to use my CanoScan N670U by Installing Windows XP Mode in Windows 7 at no additional costhttp://windows.microsoft.com/en-us/windows7/install-and-use-windows-xp-mode-in-windows-7 After install the software loaded and the only trick was to click the "USB" dropdown in the virtual machine menu at the top of the screen and select canoscan
11/5/2013 7:19:06 PM • Canon CanoScan... • Answered on Nov 05, 2013
Looking for CanoScan 670U scanner windows 7 driver
You may have luck with this WEB site. VueScan 9 scanner driver - compatible with over 1750 scanners http://www.hanrick.com/
11/13/2012 8:50:20 AM • Canon CanoScan... • Answered on Nov 13, 2012
Ive got a major problem downloading a driver for
Hi JonathanThe links are all herehttp://www.canon.co.uk/Support/Consumer_Products/products/scanners/Others/CanoScan_N670U.aspx?type=download&page=1Just choose your OS and language
10/15/2011 9:50:52 PM • Canon CanoScan... • Answered on Oct 15, 2011
When I push the SCAN button I get a message that
You need to set up the destinations in the Canon software. First launch the Canon Scan-Gear Toolbox. The Scan button on the scanner is the same as Scan-1 button by default but no software is linked to this button. Click on the Scan-1 button then choose Set. Then set your application that you will want to work on the scanned image. Select your application (Photoshop Elements, for example) - the exe file if using Windows. (You may need to browse the Program Files folder and then the individual application folder (C:\Program Files in recent versions).) Then click Open and then Apply to confirm this. You can also select the file type that you want the scans to be saved as in this settings window.
If you want to change the scan destinations, then click on Settings (on the far right). You will see the drop-down menus for each of the scanner buttons. Select the desired function for the scan button and click OK. (Scan-1, Scan-2 and Scan-3 can be linked to other software.)
I hope this helps.
10/10/2011 11:14:55 PM • Canon CanoScan... • Answered on Oct 10, 2011
I have downloaded the scanner
This was a problem with Mac's and this scanner (are you using 10.3 OS)?
Try unplugging the scanner then replugging it in, sometimes after the mac sleeps and is woken, the scanner will not be recognised (happened on XP and Vista PC machines as well)
also try using image capture on the mac rather than the canoscan toolbox software.
If you want to give installing the drivers and software another go, download the software and driver remover tool from canon's site before re-installing
7/27/2011 9:27:26 PM • Canon CanoScan... • Answered on Jul 27, 2011
I need a driver for
- go to this link: http://www.usa.canon.com/cusa/support/consumer/scanners/canoscan_series/canoscan_n670u#DriversAndSoftware
- choose what operating system your using
- download and install the latest driver
- restart the system
5/19/2011 8:15:23 PM • Canon CanoScan... • Answered on May 19, 2011
I am getting a disc
Click Start
Click My Computer
Right-mouse click on the icon for the 'C:' disk-drive.
Click Properties.
What percentage-full is displayed?
5/15/2011 10:46:12 PM • Canon CanoScan... • Answered on May 15, 2011
Cannot reload my N67OU to
You can download the scanner driver from the Canon WEB site. This is the URL to their WEB site, select your model scanner to download :-
http://www.canon.com.au/en-AU/Support-Services/Drivers-and-Downloads
4/20/2011 4:06:12 AM • Canon CanoScan... • Answered on Apr 20, 2011
After reformatting my computer I
Please check whether your scanner gets detected while connectiNg to your PC. If not please check your cable.Did you down loaded the correct driver that is meant for your OS? Please check. One more thing is the PCB at the bottom of your scanner is getting heated up? Then it canbe a problem regarding your PCB. Just replace it
4/18/2011 2:21:10 PM • Canon CanoScan... • Answered on Apr 18, 2011
I need a driver for
CanoScan N67OU Drivers
Visit the above link from Canon Official Support. Select the Operating System (OS) you have on your PC and download the required drivers & software.
Hope it helps! Good Luck!
CreativeTECH
4/18/2011 9:25:11 AM • Canon CanoScan... • Answered on Apr 18, 2011
I have problems with TWAIN
I have many years repairing canon scanners so here is my suggestion to you.
I would first google Canon CanoScan N670U drivers. Make sure you download them from the official canon site the drivers are free. All the drivers have a date on them so download the newest drivers. Once the download is complete disconnect the cable from your scanner that goes to your computer then install the new drivers. Once there installed then connect your cable from your scanner back to the port on the computer. A window should pop up saying new drivers are being installed. Once this completes then I would re boot your computer and you should now be able to scan again. Also while your on Canon's website download Capture Perfect its free too and will help you with your scanning projects.
I hope this helps you out.
4/1/2011 5:03:19 AM • Canon CanoScan... • Answered on Apr 01, 2011
I have Canon N670U scanner
The driver support site is here:
But i am sorry to tell you that the driver does not exist
for your system.
You can try to download the Vista driver
and select compatible mode when you install the driver.
Hope this was helpfull.
3/22/2011 8:28:00 PM • Canon CanoScan... • Answered on Mar 22, 2011
Canon CanoScan N670U Flatbed Scanner Logo
89 questions posted
old marine
old marine
ZJ Limited
ZJ Limited
View Most Popular
CanoScan Canon
  • CanoScan Canon
Most Popular Question
driver canoscan n670u windows 7 64 bit
  • Office Equipment & Supplies
