20 Most Recent
Canon VC-C4 Network Camera Questions & Answers
I need a solfware to install this camera to my
1st You download Webcam Driver.
Canon VC-C4 Network Camera Driver
After this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
Look to find remote and power supply for vc-c4
The VC-C4 uses a Canon WL-V5 remote control, available at B&H Photo
here. They also have a power supply for the VC-C50 here. The VC-C50 is almost identical in specification to the VC-C4, it's just a newer model. The electrical power requirements are the same.
Canon VC-C4 vs Logitech webcam
DO you realize that this camera cost around 900 US$? - Might be a little overkill for VOIP.
Apart form that it is an excellent camera. Have look at the manual
here.
The camera connects via RS232 (9DSub) or 8pin DSub and you can/have to download the software form Canon's web page.
Tengo una Copiadora Canon IR 1023, a cada rato se atasca el papel, se queda al pasar por el rodillo del termico no sale, se arruga y atasca.
Si tu copiadora Canon IR 1023 se atasca constantemente con papel y se arruga al pasar por el rodillo t?rmico, aqu? hay algunas soluciones y pasos que puedes intentar:
1. Verifica el tipo y la calidad del papel: Aseg?rate de utilizar papel de calidad y del tipo adecuado para tu copiadora Canon IR 1023. Utilizar papel de baja calidad, h?medo, arrugado o demasiado grueso puede causar atascos.
2. Limpia el rodillo t?rmico: Si el rodillo t?rmico est? sucio o presenta residuos de tinta o polvo, puede provocar atascos de papel. Apaga la copiadora, desench?fala y deja que el rodillo t?rmico se enfr?e por completo. Luego, utiliza un pa?o suave y limpio ligeramente humedecido con agua para limpiar cuidadosamente el rodillo t?rmico. Evita usar productos qu?micos agresivos o solventes, ya que pueden da?ar el rodillo.
3. Revisa las gu?as de papel: Aseg?rate de que las gu?as de papel est?n correctamente ajustadas seg?n el tama?o y la orientaci?n del papel. Las gu?as mal ajustadas pueden causar atascos y arrugas en el papel. Ajusta las gu?as cuidadosamente para que est?n en contacto suave pero firme con el papel.
4. Verifica y limpia los sensores de papel: Los sensores de papel son peque?os dispositivos que detectan la presencia y el movimiento del papel dentro de la copiadora. Si estos sensores est?n sucios o defectuosos, pueden causar atascos y otros problemas. Consulta el manual del usuario de tu copiadora para localizar los sensores de papel y c?mo limpiarlos adecuadamente.
5. Realiza un mantenimiento regular: Programa un mantenimiento regular con un t?cnico autorizado de Canon para verificar y limpiar los componentes internos de la copiadora. Un mantenimiento adecuado puede ayudar a prevenir atascos y otros problemas.
Si los problemas de atascos de papel persisten a pesar de seguir estos pasos, ser?a recomendable contactar a un t?cnico especializado de Canon o al servicio de atenci?n al cliente de Canon para obtener asistencia adicional. Ellos podr?n proporcionarte soluciones espec?ficas para tu modelo de copiadora Canon IR 1023 y brindarte un soporte m?s detallado.
What should i do to fix this error? Canon i-sensys mf 9220 showing system error E000003 on screen
What is the Canon i-sensys mf 9220 system error E000003?
The Canon i-sensys mf 9220 system error E000003 is an error that can occur when you're trying to print documents. Basically, it means that the printer can't communicate with the computer. This can be caused by a number of things, but the most common cause is a problem with the USB cable.
How to fix the Canon i-sensys mf 9220 system error E000003?
If you're getting this error, the first thing you should do is check the USB cable. Make sure that it's properly connected to both the printer and the computer. If the cable is loose or damaged, try replacing it with a new one.
I hope this helps!
Can I use my chromebook to print from a Canon MG2522
Chromebooks do not use drivers to install printers. They use Google Cloud print. There are two methods of printing with Google Cloud print, using a Google Cloud Print ready printer or setting up the service on your computer.
