20 Most Recent
Maclaren Vogue Umbrella Stroller Questions & Answers
I'm planning to buy a
You can use it, but the seat is only tested to 15 kg (in the UK) and may not last too long with a heavier weight.
Hope this helps.
Front wheels of maclaren quest 2016/2017 model are strugling to get into position they are being pushed.
It sounds like there may be a problem with the front wheel assembly on your Maclaren Quest 2016/2017 model stroller. You may want to try removing the wheels and reattaching them to make sure they are properly seated and aligned. If this does not solve the problem, there may be an issue with the wheel locking mechanism or other parts of the front wheel assembly. It may be best to contact Maclaren customer service for assistance with troubleshooting and potential repair options.
As for the safety straps, it's possible that they may need to be adjusted or reattached properly to prevent them from coming apart. The instruction manual for your stroller should have information on how to properly adjust and attach the straps. If you don't have the manual, you can find it online on the Maclaren website or by contacting customer service.
