20 Most Recent
Labtec Axis-502 Consumer Headset Questions & Answers
Had about 4 pairs of
The Left Side speaker unit(driver) of the headphone is different from right side. left side has more connections and soldering points, main cable goes to left side and chances of oxidization is more, because of cable movement(if cable goes to both sides of the headset, than it damages the side where cable movement is high). try to carefully open the headset and check the connectivity with multi-meter, If it is cable problem then trim the cable and re-solder. Or as you told you have 4 pairs, and you have broken ones. swipe the speaker unit (drivers). Besides both left and right drivers have different connections, it is possible with little soldering knowledge. hope you got it. thank you
How to wire a fridge thermostat
Wiring a fridge thermostat typically involves connecting the thermostat to the power source and the compressor. Here's a general guide for wiring a 3-pin thermostat:
- Identify the Pins: The thermostat will typically have three pins labeled 4, 6, and 3.
- Connect the Power Source: Pin 4 is usually the common (C) terminal, which connects to the power source. This could be the live wire from your electrical supply.
- Connect the Compressor: Pin 6 is often the normally open (NO) terminal, which connects to the compressor. This allows power to flow to the compressor when the temperature rises above the set threshold.
- Ground Connection: Pin 3 is commonly the ground (GND) terminal. This should be connected to the ground wire for safety purposes.
4/19/2024 7:20:26 AM •
Radio...
Answered
15 hours ago
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
Serial Number for KPG-790
All questions need FULL 'make model (what it is) first 3 words please.
Something to do with this? The serial number should on the label on the rear by the mains cable. This is a statutory requirement unless someone removed it to hide its identity.
https://www.google.com/search?q=KPG-790
2/15/2024 3:06:45 AM •
Radio...
Answered
on Feb 15, 2024
