20 Most Recent Dell 3000cn Color Laser Printer Questions & Answers
Paper transport does not work; terrible grinding noise
I took mine apart from the back and put it back together and it worked. It is probably due to moving it and the bottom paper tray alignment gets out of whack. I inspected all of the gear train and didn't find any worn or missing teeth. I suspect a paper jam started it and the user turned the printer around to open the back door. Since the handles are on the printer the tray doesn't move with it which allows it to separate and possibly jam a pickup drive gear.
2/9/2022 1:43:12 AM • Dell 3000cn... • Answered on Feb 09, 2022
2answers
Dell 3000cn color printer - black/grey line down
Sounds like the black drum. You can't get the part from anyone but Dell so be prepared for the cost. It also requires some disassembly to install on my Dell 5110cn so yours most likely will also.
11/21/2019 6:38:12 AM • Dell 3000cn... • Answered on Nov 21, 2019
2answers
I need the Dell 3000cn printer service manual
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&l=en&s=gen&~ck=anavml
You can download the manual from the above link. If that doesn't work, go to support.dell.com and follow the links to the downloadable manual. Start on the left hand side by selecing Manuals (found under the "Product Support" heading)
11/20/2019 12:05:56 PM • Dell 3000cn... • Answered on Nov 20, 2019
Excess toner after ?overfilling cartridge w/ bulk toner
Did you refill the toner yourself or put a new one in or.......
2/28/2017 1:30:46 PM • Dell 3000cn... • Answered on Feb 28, 2017
I had a paper jam in the back and I'm afraid I jerked the paper out - now I get paper jam message and it won't pick up paper.
You will need to open the printer and where the wheel is to grab the paper look in both corner ans there maybe a piece of paper stuck in it. Even if you open the doors to check it;s hard to see the edges of the roller
2/4/2015 12:22:01 AM • Dell 3000cn... • Answered on Feb 04, 2015
Error code says invalid pdl file
Uncheck the "Enable advanced printing features" checkbox under the Advanced tab in the printer's Properties page. I've observed this causes the print job to fail when I've attempted to print via USB cable. Also, any advice you read that suggests printing directly to printer isn't sound advice. You need to spool your job, or otherwise a large job that does not fit the printer's available memory (buffer) DOES NOT fail gracefully.
5/21/2014 7:24:29 PM • Dell 3000cn... • Answered on May 21, 2014
0answers
2answers
Dell 3100 CN replace drum cartridge
No. There is no reset as there is with some units. This unit actually knows via a smart chip in the drum unit if it has reached EOL ( end of life ).
2/22/2013 6:55:12 PM • Dell 3000cn... • Answered on Feb 22, 2013
2answers
Error Code 004-332
try unplugging it for about 10 minutes and starting it up again... that hopefully will reset it.... have you found out what that error code is
Robert
11/10/2012 2:10:27 PM • Dell 3000cn... • Answered on Nov 10, 2012
0answers
How to disassemble dell 3000cn
My printer is giving blurred colour images I have changed the photoconductor and the same happens so it is definatly the printer any help
5/3/2012 12:46:14 PM • Dell 3000cn... • Answered on May 03, 2012
Can a laser unit be cleaned or does it need to be replaced
Hi Dear, You should change the drum of your laser unit.
3/28/2012 7:34:57 AM • Dell 3000cn... • Answered on Mar 28, 2012
0answers
Dell 3000cn has vertical white lines on
Copied from the Dell community forums:
This is from a previous post and may help with your problem. I have printed 1000's since I came up with this fix with no recurrence of any streaking. Let me know how this works for you. I have come up with the cause and a fix for the above problem. This also fixes the problem of lines running the direction of paper travel on color prints. Black and white prints are OK. If you have a warranty on your printer or drum unit then you can have the drum unit replaced and hope you get a good replacement drum unit. To fix your drum unit do the following: 1. Remove the drum unit from your 3100cn. 2. Set the drum unit on a clean level surface and avoid touching the drum or the transfer belt (the decal with 4 arrows points to the transfer belt). 3. Remove the 6 screws from the top cover (the cover has the blue handle attached). Two screws are on top at both ends of the blue handle. The next 2 screws are on the sides and line up with the decal with 4 arrows. The last 2 screws are also on the sides and at the lower corners of the big decal that shows how to remove the drum unit from the 3100cn. 4. Carefully lift the cover from the drum unit and cover the drum unit with clean paper to protect the transfer belt from bright light. You can carefully reinstall the drum unit without the top cover and run some color prints. If the lines are gone then continue with step 5. 5. Look at the ribbed side of the top cover. Some may show some toner build-up. Some of the rib intersections are too high and are dragging in the toner that is applied to the transfer belt. The ribs are there to add stiffness to the cover and to keep it from bowing. 6. Place the cover handle side down on a clean towel. 7. Using a palm sander with 320 grit sandpaper and light pressure (the weight of the palm sander) sand until the ribs going both directions are showing signs of being sanded. You will be able to see the difference as unsanded areas will be glossy and sanded areas will have a dull finish. 8. Switch to 600 grit paper and do a light sanding. 9. Wash the cover under cool water. Don't use hot water since that could cause the cover to bend. 10. Dry completely. I used compressed air. 11. Reinstall the cover to the drum unit. Tighten the 4 side screws first and then the 2 top screws last. 12. Put the drum unit back into the 3100cn and try a color print. 13. Please post if you have any questions about the procedure. 14. If your next drum unit has the same problem you can swap top covers.
Message Edited by Ron13863 on 09-04-2007 07:16 AM
2/27/2011 7:23:14 AM • Dell 3000cn... • Answered on Feb 27, 2011
[email protected] I can
Here you go you could print this out too.
1/10/2011 6:59:34 PM • Dell 3000cn... • Answered on Jan 10, 2011
2answers
Dell 3000 0004-321 error code
code 004-321 Restart Printer will not shut of once I turn off/on the printer
7/28/2010 1:23:51 PM • Dell 3000cn... • Answered on Jul 28, 2010
What is a ram disk on a 3000cn dell printer?
SDRAM SODIMM , same memory used by laptop.
4/8/2010 5:31:15 AM • Dell 3000cn... • Answered on Apr 08, 2010
Dell 3000cn Color Laser Printer Logo
78 questions posted
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
error code says invalid pdl file
  • Office Equipment & Supplies
