20 Most Recent Dell 1600n All-In-One Laser Printer Questions & Answers
There is a button right above the "Start Scan" button that says "Select Software". Use the arrow buttons (located over the Cancel button) to change how the documents are scanned.
Dell 1600n... | Answered on Nov 04, 2019
Hi go into settings on you're printer & clear the pending queue it will not print till u delete them ..cheers
Dell 1600n... | Answered on Jan 18, 2018
Scanners, when broken, are irreparable. (or at least thats what I was told when I worked for Dell)
Dell 1600n... | Answered on Jan 03, 2018
Do a hard reset of printer to erase all memories. Then also uninstall and reinstall the driver and see what happens. Also make sure that you are using the correct driver for your OS
Dell 1600n... | Answered on Sep 12, 2017
Rollers may look good but it sounds like they need to be replaced. You will need the separation and pick up rollers.
Printer Repair Service in Miami and Fort Lauderdale FL
Dell 1600n... | Answered on Jun 06, 2017
BUY a new DELL cartridge . most mfg's have put chips on them that will not let the printer use a non OEM cartridge
Dell 1600n... | Answered on Mar 08, 2016
Hi
Grinding noises indicate either gears that are self destructing or something is stuck inside. Take out the cartridge(s), remove the paper and all the plastic that comes off. Unplug the cables. Now lift the printer, turn upside down and shake. If there are broken gears a local repair shop might try to fix it but most stores refrain from this.
Dell 1600n... | Answered on Mar 23, 2015
Have you opened the printer and inspected inside the case?
Whatever you do, don't poke around inside the printer with sharp tools.
Dell 1600n... | Answered on Feb 05, 2015
Had a similar problem on a HP MFC3330
Fixed it with the following video aid:
"how to fix the scanner bulb warming up error hp 3330 or repair 3380 scanner bulb warm up problem - YouTube"
http://youtu.be/lqG_nmi3vC4
Hope it helps...
Dell 1600n... | Answered on Jul 30, 2014
[Clearing the Memory]
You can selectively clear information stored in your multi-function printer's memory.
Press <Menu> on the operator panel until "Maintenance" appears on the top line of the display. 1.
Press the scroll button ( or ) until you see "Clear Setting" on the bottom line and press <Select>. 2.
The first available menu item, "Paper Setting" displays on the bottom line.
Press the scroll button ( or ) until you see the item you want to clear.
Paper Setting: Restores all of the Paper Setting options to the factory default.
Copy Setup: Restores all of the Copy Setup options to the factory default.
Fax Setup: Restores all of the Fax Setup options to the factory default.
Fax Feature: Cancels all of the scheduled fax jobs in the printer's memory.
Advanced Fax: Restores all of the Advanced Fax setting options to the factory default.
All Settings: Clears all of the data stored in the memory and resets all of your settings to the
factory default.
Sent Report: Clears all records of your sent faxes.
RCV Report: Clears all records of your received faxes.
Phone Book: Clears the speed dial or group dial numbers stored in the memory.
3.
Press <Select>. The selected memory is cleared and the display asks you to continue clearing the next
item.
4.
Repeat steps 2 and 3 to clear another item. 5.
OR
To return to Standby mode, press <Return>.
[Page 130]
Dell Laser Multi-Function Printer 1600n User's Guide
ftp://ftp.dell.com/Manuals/all-products/esuprt_printers_main/esuprt_printers/dell-1600n_User's%20Guide_en-us.pdf
Dell 1600n... | Answered on Jun 13, 2014
Dell 1600n All-In-One Laser Printer Logo
372 questions posted
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
new toner cartridge installed printer
  • Office Equipment & Supplies
