20 Most Recent Creda W100FW Front Load Washer Questions & Answers
Drum will not rotate during spin cycle-Creda Washer Model 17064E
Replace the carbon brushes on the motor
2/2/2018 7:16:42 PM • Creda W100FW... • Answered on Feb 02, 2018
I need a manual for a creda simplicity 1000 w200fw
Google it
2/2/2018 7:16:00 PM • Creda W100FW... • Answered on Feb 02, 2018
Creda water level sensor
You have a blockage in the syphon assy or a split syphon pipe
2/2/2018 7:14:06 PM • Creda W100FW... • Answered on Feb 02, 2018
My Creda simplicity 1000 washing machine wasn't draining or spinning now there's no power light coming on and does nothing when i turn it on is it un repairable
It could be a lot of different things. Maybe the timer. If you know someone who has a volt meter and knows how to use it. Find you machine with a Google search, look for trouble shoot washing machine timer. That's the way I would do it. You want to look for a open in the electrical system *{the switch} like a broken wire inside the switch. Make sure to unplug the machine first. You won't need the power on for the first tests. A volt meter can be purchased for under $10. and any home repair store or box store.
12/14/2014 8:52:47 AM • Creda W100FW... • Answered on Dec 14, 2014
0answers
Used non he detergent in front loading washer
That wont hurt anything but if you put a lot in you may have a suds problem. My whirlpool has a suds reducer that will take out the extra suds. I am not sure it yours has that set up or not.
4/24/2014 2:22:30 AM • Creda W100FW... • Answered on Apr 24, 2014
0answers
2answers
Creda aqua wave 9.5kw electric shower, no hot
my Creda Aqua 9.5 shower loses water temp when water pressure is increased. i have a very low pressure at the moment.why?
1/31/2014 8:14:34 PM • Creda W100FW... • Answered on Jan 31, 2014
Whirlpool 1000 w100 stops after filling with water
see this causes and fix it. God bless you Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem. Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components. Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer 10_1_2012_5_14_29_am.gif
1/9/2014 5:38:33 AM • Creda W100FW... • Answered on Jan 09, 2014
2answers
Bearing replacement on Creda IWD 12drum DIY or not?
no im afraid thisis not a DIY job and i charge £120 pounds to supply and fit new bearings and spider  and you should also get @ least 6mths g/tee on parts fitted         good luck
12/10/2013 10:27:54 PM • Creda W100FW... • Answered on Dec 10, 2013
were is the filter
11/28/2013 3:45:09 PM • Creda W100FW... • Answered on Nov 28, 2013
0answers
2answers
Blocked drain
Is there still water in the machine or have you bailed it out? Some units have a serviceable water pump, meaning you can take the bottom of the pump off and clear gunk that has plugged it up. When you manually turn the dial to spin cycle, does it spin and push any water out even a tiny amount at a time? If not, take a large bucket and then place it on the floor next to the machine and place the drain hose in it. The bucket needs to be lower than the water level in the machine. When you do this, does it drain? If so this would solve the issue of whether or not the pipes are plugged. If in both cases either on spin or with the hose lower than water level, if it only drains a tiny stream then you do have a plugged line and you would need to disconnect the hoses from the pump under the machine and clear the plug. Be prepared for a lot of water to come out when you take the hose off of the pump. The plug is most likely in the hose coming out the bottom of the tank going to the water pump. This item has the hose leaving the machine going to the house drain. The other large hose goes up to the bottom of the tank. Good luck and let me know if you need more help.
9/13/2013 3:28:32 AM • Creda W100FW... • Answered on Sep 13, 2013
Door interlock
Probably blown a track on the timer pcb, you need to remove the timer to check for short circuit.
9/6/2013 2:42:42 PM • Creda W100FW... • Answered on Sep 06, 2013
Creda W100FW Front Load Washer Logo
131 questions posted
Top Creda Washing Machines Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Creda Washing Machines
Most Popular Question
fills water blows fuse
  • Washing Machines
