20 Most Recent
Vizio E221va 22 in. TV Questions & Answers
I need remote code to set upon Dish remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window " to get gathered related posts.
5/28/2016 11:11:19 AM •
Vizio VA...
Answered
on May 28, 2016
What are the universal remote codes for this TV
Programming Notes
5/27/2016 3:01:24 AM •
Vizio VA...
Answered
on May 27, 2016
My tv picture keeps going black
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
3/31/2016 7:36:07 AM •
Vizio VA...
Answered
on Mar 31, 2016
Screen seems stretched. How do I fix it?
https://answers.yahoo.com/question/index?qid...
Jul 21, 2013 - Ive had this tv for almost a year and the screen has never given me problems, but just recently all the HD channels are stretched. ... If your Vizio is like my 47" it has 4 Picture Modes - Wide, Normal, Zoom and Panoramic. ... Why isnt my viziotv able to play full screen hd channels?
Aug 23, 2008 - It is a High Definition Vizio TV. The center of the screen is clear, but the television stretches the image out on the sides. Is there anyway to fix ...
1/1/2016 1:52:50 AM •
Vizio VA...
Answered
on Jan 01, 2016
Vizio TV Input Menu Scrolling
Read the recommendation about holding the Input button of the side of the Vizio TV to 'reset' the Input option. The scrolling was driving me a bit nuts so I tried it and "IT WORK GREAT". Certainly beats having to replace the circuit board recommended in other suggestions submitted.. Thank you for you helpful advise.
I HAVE VIZIO 70 MODEL E701i-A3 TV WAS ON SCREEN WENT BLACK I PRESS A BUTTON ON THE REMOTE AND THE SOUND WENT OFF. AFTER THAT THE TV WOULD NOT RESPOND AT ALL.
Try a hard reset to this set, and check. If it do not help you, contact any service technician.
There are two types of reset to TVs.
The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
4/24/2015 6:00:19 AM •
Vizio VA...
Answered
on Apr 24, 2015
My tv screen is stuck in photo menu
Do a reset to this set and check. To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
10/29/2014 1:16:42 AM •
Vizio VA...
Answered
on Oct 29, 2014
