20 Most Recent LG 55LS4600 55 Inch 1080p 120Hz LED LCD HDTV - 54.6 Inch Diag Questions & Answers
Lg 55ls4600 wont turn on and blinking red light.. what could be the problem?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
11/1/2016 2:35:10 PM • LG 55LS4600 55... • Answered on Nov 01, 2016
55ls4600 blank screen, backlight is working. Main Board
If the T'Con board has failed, this should happen. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/24/2016 4:25:31 PM • LG 55LS4600 55... • Answered on May 24, 2016
LG LED TV powers on, backlight works but no picture. What should I look for / replace?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
11/23/2015 5:12:02 AM • LG 55LS4600 55... • Answered on Nov 23, 2015
I have a LG dvd player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning. Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem. Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates. Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV. The hum is simply the player trying to read the disc. It can't so, it spits it out. Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
4/19/2024 8:46:44 PM • LG Televison &... • Answered 31 minutes ago
3answers
Fuse diagram for a LG plasma model pdp42v80201
The screen blank out
4/7/2024 11:03:07 PM • LG Televison &... • Answered on Apr 07, 2024
LG Plasma TV is not displaying picture when it is turned on
This is the Power Board for it. check those 6 electrolytic Capacitors on the right for bulging or splitting. Don't buy it blindly, it's a guess. The output voltages with a digital multimeter. https://applianceparts.com/item/10217204/LG/EAY62812602/ Many parts are obsolete. eBay has used boards, but they are risky because they are out of scrapped sets. https://www.google.com/search?q=50PN5300-UF+power+board We have a television expert named Larry, but I haven't seen him for a while. This used to be my advice https://www.fixya.com/support/r29790007-repairing_own_television ..
3/30/2024 8:59:29 PM • LG Televison &... • Answered on Mar 30, 2024
3answers
DVD reading problem on a LG DVD5083 DVD player.
Maybe the disk is not compatible with the DVD player version
3/24/2024 9:16:41 AM • LG Televison &... • Answered on Mar 24, 2024
How do I program my DVD video remote control to my LG Blu Ray surround sound player please?
It can't be done. The DVD remote will be single frequency for that device only and the LG remote for that LG Blu Ray (or series) only. Companies don't make cross-control between makers easy. The only exception is cable and satellite boxes to allow their remote to also control the television. If you have lost a remote or it doesn't work, this is the answer https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/19/2024 4:25:52 PM • LG Televison &... • Answered on Mar 19, 2024
LG BD590 250 GB HD Network Blu-ray Disc Player. How to make LG BD590 region free?
Question edited for a lot more clarity. All in the link https://www.google.com/search?q=LG+BD590+make+region+free ..
3/17/2024 3:28:16 AM • LG Televison &... • Answered on Mar 17, 2024
How can I program my LG DVD remote control COV33662806 to my LG 55 Roku television.
You can't, the LG DVD Remote is single frequency. If you are lucky, the LG Television Remote, might control an LG DVD. If you have lost a remote, have a read of this https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
3/15/2024 11:09:16 PM • LG Televison &... • Answered on Mar 15, 2024
Could you help diagnose the issue with my LG TV MODEL 65UN7300AUD that does not power on?
If you would like to share any clues, yes. Checked power going in, I presume. Any indicator lights? If yes, how many times does it flash?
3/15/2024 7:15:50 AM • LG Televison &... • Answered on Mar 15, 2024
2answers
My LG DVD/CD receiver Model:LH-D6246,Shows disc 'error' when I load a dvd or cd disc but the radio plays very well please help
faulty dvd reading lens,should be change by expert professional
3/14/2024 12:44:09 AM • LG Televison &... • Answered on Mar 14, 2024
How to activate universal remote control AMELY AD-UL101S with LG TV Brand or other brand?
Question edited for clarity and add maker. No one uses Universal Remotes these day. You buy a Remote that is a Copy of the original. https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote The AMELY is a very cheap and nasty Chinese Remote and they don't supply instructions!! https://www.amely.cn/AD-UL101-S-AMELY-unviersal-TV-LCD-LED-remote-control-p636185.html Codes are decided by the brand of television. This is for LG https://www.google.com/search?q=universal+remote+codes+for+lg+tv ..
3/3/2024 4:57:30 PM • LG Televison &... • Answered on Mar 03, 2024
LG DVD Player - DSI-8555 manual please?
It appears to be a model made for the India market. https://www.google.com/search?q=lg+dsi+8555+manual This is the only service manual that is related. If the display is not working, look on the back of the display board for a split or bulging electrolytic capacitor.
SERVICE MANUAL
Encompass Parts https://research.encompass.com > ZEN PDF This manual was prepared for use only by properly trained audio-video service technicians. When servicing this product, under no circumstances should the ... 109 pages
3/2/2024 7:45:46 PM • LG Televison &... • Answered on Mar 02, 2024
My children have misplaced remote control of LG TV now there's child lock. how can i turn off child lock without a remote control?
buy replacement remote google your tv model number follows by remote.
2/25/2024 6:07:37 AM • LG Televison &... • Answered on Feb 25, 2024
What is the IP address for my LG TV model number 28LX 578M serial number 611FMXVN6763
That will show in your network settings on the tv screen under manual entry network, or automatic entry try both and then write them down when it shows them.
2/7/2024 5:48:37 PM • LG Televison &... • Answered on Feb 07, 2024
LG 55UH5500 red power LED blinks twice and I see the LED back lights flash with back off but it wont turn on. I fully replaced the power board.
There may be a backlight issue. Some of the LEDs may have failed causing the LED to stop working at the correct voltage. This will tell the main power supply to switch off as there is a problem. I would ask LG support. https://www.lg.com/uk/support/contact-us/
2/3/2024 7:32:18 AM • LG Televison &... • Answered on Feb 03, 2024
LG 55LS4600 55 Inch 1080p 120Hz LED LCD HDTV - 54.6 Inch Diag Logo
4 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
55ls4600 blank screen backlight
  • Televison & Video
