20 Most Recent
Samsung SAM4s ER-650 Cash Register Questions & Answers
I can't get the key to turn into the SM mode to clear the grand total history.. I would like to do this before I use the machine
cashregisterhelp.blogspot.com/2008/05/
sam4s-
er-
650-
cash-
register.html
May 1, 2008 - I really like the SAM4s ER-650 Cash Register and ER-650R Cash Register. ... By the way the SAM4s ER-650 and ER-650R is the same as the Samsung ER-650 and ... I can't seem to figure out how to program it to track ticket/check #'s. .....also, neither the Reg Key or Mode Key will turn to SM mode. help?
www.maxperience.com > ... > Cash Registers
If not, you will need to go to the SM mode and configure either RS-232 port 1 or port 2... Press enter (cash key) through the rest of the options. ... I could not get the curserinto the plu numeric field once i entered the plu. .... There are manuals for the SAM4s ER-650 at http://www.cashregisterguys.com and if you are looking for ...
How do i change the business name, address and abn on the receipts for a Samsung ER-650
Turn key to "PGM"
Press "7"
From the
LOGO DESC. PROGRAM screen, press "0" to display the PREAMBLE screen:
Using the alpha numeric keyboard overlay, type the first line of the message.
Each line (6 allowed) can be up to 32 characters, although only the last 19 characters you have entered will display. If you make a mistake, press the "BACKSPACE" key to erase the previous character. After you have completed typing the first line, press "ENTER"
to accept the new line and advance to the second line, or press
"ESC"
to return to the LOGO DESC. PROGRAM screen without making any changes.
Thank You
Team
ACP ONLINE
Machine deleting random PLU info
That's an interesting one. It sounds like the PLU file may have corruption. I've only had this when the battery wasn't changed on time. Make sure you have had the battery replaced at the correct service interval. It will probably need backing up and RAM clearing. Check with a dealer.
How do I program my second register using my first register
first program the irc options (#7) in the service mode making one register 1 and one register 2 . also make the max # of reg 2. then program memory allocations to be the same in program. finally connect the two with a pin to pin cable and go to download programs to send
How to delete a plu
to delete a plu it must have no totals on either the plu current or today report. Run a plu z report both current and today and then delete the plu
Setting new price for plu
Using the 'P' key, 'C' key turn the key to the PROG position, PRESS the 0 (zero) key and then 0 (zero). At this point, press the key of the item that you wish to change or Enter the PLU # and press the PLU Key. If the description of the item is ok then press 'cash/enter' and then press it again. You should be on the PRICE/Halo line, Change the amount to the correct amount and press cash/enter at this point you can then press the clear key and then turn the key to the 'REG' Position. Press the Key of the item you changed and it should display the new price.
Why is the front end display is black
the aduster potentiometer on the ride side of the cash register is very weak and with continued used will stop changing the contrast...I have found that unsoldering the adjuster and replacing it with a 1k ohm resistor fixes this problem
Need help key programing
(1) how do I program the order no: on the receipt , (2) how do I print the two copy in one single receipt , thank you
Can not open
Below the display side on your right handside , there is a switch, make sure it is on
