20 Most Recent
Samsung Sam4s ER-5200M Cash Register WITH PROGRAMMING 1-800 SUPPORT FRRE SHIPPING Questions & Answers
Samsung 5200m clear grand total
I HAVE BOUGHT A USED ER5200M. I HAVE CLEARD THE PLU'S AND RE PROGRAMMD WITH MY ITEM & PRICE INTO THE PLU'S. EACH NIGHT AFTER I DO "Z" REPORT, THE REGISTER IS STILL TOTALING MY GRAND TOTAL ONTO THE OTHER OWNERS GRAND TOTAL WITH MINE, HOW DO I CLEAR GRAND TOTAL SO IT WILL BE ONLY MY GRAND TOTAL ?
How do I program a taxable item on PLU on Sam 4s 5200m?
no, no, no....not 1 or zero before the price...that is totally wrong
In program mode, hit 100 subtotal, then press the plu to be programmed, then hit 0 time for nontaxable and 400000000 time for taxable then hit subtotal
Sam4s cash register
sam 52xxm registers use two thermal printers....so make sure the paper is thermal and not in upside down. also make sure the receipt on/off function is "on" . and finally see if the tubular black paper feed roller hasn't popped out of its socket making the paper not turn or advance
Problems cash register
if an initial clear doesn't work the keyboard is probably your source of trouble.
if it was exposed to moisture it won't do the clear. Many people have had success drying them out by pointing a small fan at the keyboard for a few hours and then try the initial clear again
How do you program a misc key
Key to P, press 100 SUBT, then press preset key on keyboard, press 000000000 (9 zeroes), press X/TIME, then press CASH
What does error code mean e21
Manual says E21 is 'Off Line'. Not much to go on there but I am guessing that is probably referring to something that is plugged into the serial ports on the side - perhaps it is looking for an external kitchen printer of something along those lines.
Training mode closed how do i re open
The training mode on the 5200 is activated using a clerk number that has been programmed to be a training clerk. To log the clerk off turn key to REG and press 0 then clerk. Then log on a clerk which isnt programmed for training - try 1 then clerk. If that doesnt work, try 2 then clerk. Clerk key is usually top right key on keyboard.
How to program the open misc button
to program an open misc key in the first 10 columns of the keyboard turn key to program and hit 100 subtotal, then press the key to be programmed. enter o and hit time , cash for a non taxable open key or press 400000000 time , cash for open taxable key
Phil
How to fix problem
THe memory is lost all you need to ddo is an initial reset and start again programming
