20 Most Recent
Fujitsu LifeBook S4510 Notebook Questions & Answers
Hi,hope you can help.I have
Hi, to start you can go to network connection , and try to start connection manually.
Try also unplugging power cord and removing battery, this can reset wireless adapter status.
If that does not help, the fastest way to proceed is reinstalling drivers.
Drivers can be downloaded from Fujitsu website,
entering model number here.
Audio driver does not work
http://webdownload.fujitsu-siemens.com/download/FileDownload/fileDownload.aspx?SoftwareGUID=E0F26D05-EC92-4706-BCEF-2E0FBF613E6B&FileFolder=Downloadfiles&FileTypeExtension=ZIP&FileNameClient=FSC_SoundSigmaTelAC97Audio_512017117_1002446.ZIP&FileSize=79071&From=UXJwY19rRGdqY1JtQHBtdXFjcCIk
if helped rate fixya
Fujitsu siemens amilo li2727
In general, if you remove the battery in the notebook which holds the bios setting / password. This may clear the password & revert the bios to its default settings. If you have the manual the correct model number should be there.
emove the panel containing the power switch; the jumper (called J1) is located next to the plug for the status panel LCD. Briefly place on pins 1-2 about 10 seconds, then replace to pins 2-3. That's all, except closing up the machine again!
BIOS Password - UNKNOWN
Remove the battery. That will clear the cmos known as the bios. Check the manual there may also be a jumper that can also clear the bios. Remove the battery & unplug the power before doing this.
please vote...
Need help
your problem could be that the hard drive is broken, perhaps with some tool to repair hard disks the problem. test starting for example hiren boot from a memory or cd and see if it recognizes the hdd, if so you can pass some repair tool
How can i reset bios code ?
remove the bios password by removing the
cmos battery, removing the jumper from the pins right next to the battery, marked something like pswd, plugging it in and hitting the start button.Before you open the
case, unplug, remove the bettery, then hold the start button to get rid of any energy.
Keyboard
Sounds like liquid may have been spilled on the keyboard.
Plug in an external usb keyboard and check if it works.
If so, you will need to buy a replacement keyboard and swap it out, best cheap from Ebay.
Where is my print screen button
Often you find it at (or towards) the right top area. This is not possible to confirm without knowing what computer/keyboard/Operating System you use.
It may be abbreviated as "PRT SC" or similar and often is in connection with an Alt key. If you have a dedicated Numbers keypad it should be to the top of that.
For better answer please ask with more details.
How do I turn off numbers lock on Fujitsu Lifebook e sereis
Hi
According to the manual which I found available for download here:
File description
there is a button on the keyboard marked "num" and this toggles the virtual number pad on and off. I cannot however find a diagram, or any indication in the manual as to where on the keyboard this button is.
Hope this is helpful, if so would you please register that with Fixya
Cheers
