20 Most Recent
Gateway 4525GZ Notebook Questions & Answers
My gateway 4525 battery is 95% charged but won't tune the computer
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.
The resolution on my monitor
The resolution of your system has been decreased. Follow the following steps to increase/ adjust the screen resolution.
1. Open Display Settings by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
2. Under Resolution, move the slider to the resolution you want, and then click Apply.
Please note that When you set your monitor to a screen resolution that it won't support, the screen will go black for a few seconds while the monitor reverts back to the original resolution
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
How do i use my wireless ethernet?
If you are in a network, you need to have a thing called IP address which is usually assigned by a DHCP server or a wireless access point.If DHCP Server is not available in your case then you need to configure evreything manually.If DHCP server is available then you don't need to configure anything.Just search for the WI_FI signal and connect with it.
For manually configuring Wireless Network Setting
Go to control panel and click "network and Sharing Center", click Change Adapter settings" Right Click on the wireless adapter, Select "properties", click on "Internet Protocol version 4(TCP/IPv4)".
Select now use the followinf IP address,
Manually fill the IP address :
Subnet mask :
Default Gateway:
Select "Use the following DNS address "
Manually fill Preferred DNS address:
Alternate DNS address:
For example : IP address : 192.168.0.10
Subnet mask : 255.255.255.0
Default Gateway :192.168.0 1
Preferred DNS address :218.248.234.117
Alternate DNS address :218.248.136.142
IP address is needed for communications between devices.
subnet mask is needed for identifying your Network Address Node.
Default Gateway is usually your Router or Wi-Fi access point IP Address.
DNS address for resolving domain name(mostly for Internet browsing)
Hope you can connect it now.
HAPPY NEW YEAR.
My resolution messed up!
Please ensure that your Video /VGA/ graphics driver is installed.
I recommend you to uninstall the VGA graphics driver and use the motherboard driver cd which provided along with your laptop to reinstall the drivers back. Then the problem with your display should be fixed.
If you are not having driver cd, then download your driver from manufacturers website for your exact model.
I hope this information is helpful for you.
Please rate the solution provided.
Thanks
Where is the wireless switch located?
Try to examine your laptop keyboard.
- Look for a Function Key (F1 ... F12) with the wifi icon below it usually printed in orange or blue.
- Now press and hold the Fn key and press that function key with the wifi icon.
- That softly turns your wifi ON.
The resolution on my monitor is messed up. Its as
In windows xp -
1. Right click on the desktop
2. Click on properties.
3. Select Windows XP Theme. (this is the default theme)
On Vista --
2. Select personalize.
3. Select Themes
4. Select Windows Vista from the drop down box.
This should set everything back to the default settings as far as the appearance goes.
No power no screen
It is a hardware problem. May be your laptop power supply has been faulty. so pls you can check it from service center.
How to replace a DVD drive?
Turn the laptop upside down. take out the battery and the pwoer cable from the back and you might need a philips screw driver handy. you would see a hole and a lock image under the laptop.
as shown in the image open the screw and then use the flat head screw driver and pop the drive out of the computer. and undo the same steps to pop the other one back in.
There is no sound coming from my gateway 4525gz
Reinstall the audio drivers from the manufacturers CD. If you didnt get one ,download the latest drivers from the manufacturers website. Restart the system after installation.That would make it run.
PS: confirm with the dealer wether you have a sound card or not.
Gatewat 4525GZ Intermittenly cant find DVD/CD Drive
The fact that the CD ROM works at all means them MOBO is ok..just replace the CD ROM as they are not that expensive any longer and save yourself some headaches..good luck. Let me know if you have have questions.
Rate with 4 diamonds.
Operating system & harddrive not found
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk?
In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free
Grisoft Home Page
- Spybot S&D
Spybot Home page
- AdAware
Lavasoft Home Page
Basic versions are either free or ask for donations.
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor.
The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port.
I hope this helps.
1/18/2024 10:32:24 PM •
Gateway...
Answered
on Jan 18, 2024
