20 Most Recent Canon Pixma Mx432 Wireless Inkjet Office All-in-one Printer 5783b002 Questions & Answers
You might try cleaning the rollers that pull in the paper. I use alcohol and a swab. Let the rollers dry before running paper through.
Canon Pixma... | Answered on Mar 14, 2016
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Canon Pixma... | Answered on Jul 21, 2014
hi there, you can take the ink out of the printer and uninstall the software on the computer :-)
Canon Pixma... | Answered on Jun 10, 2014
Please go to:
http://www.drivermanager.com/en/drivers.php?Brand=Canon&Logo=canon&gclid=CIjp0tH147QCFcqY4AodXykALA
Canon Pixma... | Answered on Jan 12, 2013
Can you call the company or the manufactor and see if they can send one to you? Or maybe the store you got it from might help you out.
Canon Pixma... | Answered on Jan 04, 2013
i can't turn on my canon ip2770 after resetting it.
Canon Office... | Answered 21 hours ago
Hi. you need to enter in service mode
with the machine turned on, in the control panel do the next key secuence:
press adittional function
press 2
press 8
press again adittional function.
service mode should appear in the screen: (#SSW)
tap in the arrow ? or ? and search for CLEAR
press OK once, with arrows search for ENGINE and press Ok once, with arrows search for ERRCLR and press OK once more.
turn off the machine from the main switch for about a minute and restart it. try to make some copies, if problem persist there is a malfunction in the fixing unit, get technical support.
if this answer was helpfull , please rate it. thanks
Canon Office... | Answered Yesterday
Canon Pixma Mx432 Wireless Inkjet Office All-in-one Printer 5783b002 Logo
Popular Tags
18 questions posted
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
fix paper jam when paper pulling angle
  • Office Equipment & Supplies
