20 Most Recent
Canon Canoscan 9000f Color Image Scanner Questions & Answers
Scanner led 110 error code: 217916
the cause is that usb cable supplies power to scanner(there is no power cable) and therefore can not be much long, plug the original cable from scanner directly to USB port in your PC and it will be working correctly. If you use additonal cable to connect scanner to your pc you wil get the error code
Scan drivers not installed
Did you receive a driver with your printer? If not you need to have one in order to install the software for the printer, in order for it to work properly.
