20 Most Recent
Topcon Rl-h3cl Long-range, Self-leveling Rotating Laser Questions & Answers
No power
It could be a few things.
1. Bad keypad / power button ($30.00 and labor)
2. The power connection is lose from the main board.
3. Corrosion on the rear battery terminal.
4. Lose connection / Battery Springs
5. Bad Main Board.
Most of the time when a laser will not power on, it is a battery connection issue. You can carefully open it and inspect the wiring (red and black cable that goes to the green main board)
If the only problem is that it wont power on I'd be willing to bet it's repairable. Those units are notorious for not holding calibration. If you drop one chances are it may no longer hold calibration due to a bad compensator.
Any laser dealer with a service center should be able to pop that thing open and fix it pretty quickly
If you don't want to pay to have it repaired, open it and check the connections. Be careful not to touch anything unless you have an esd wrist strap, or you could damage the main board. At this point it's already broken so there is no harm in trying.
Problem with oelmaier pac2 inverter
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjckMaPzKODAxUVj4kEHR5mBFMQFnoECBQQAQ&url=https%3A%2F%2Fforums.whirlpool.net.au%2Farchive%2F1447917&usg=AOvVaw1FGjdFQoufkwdXZJgXWdGz&opi=89978449
Inverter problems
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwj_qqPyyKODAxWLHjQIHZRbAW8QwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DZ6e4aMeAfGQ&usg=AOvVaw1gC1aMLjnqHmsV7v7EZaQm&opi=89978449
Rca 16mm projector 201 pg no sound exsiter lam of
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiX9MCToeeCAxWXv4kEHeF-DZcQFnoECCEQAQ&url=http%3A%2F%2Fwww.film-tech.com%2Fubb%2Ff1%2Ft000301.html&usg=AOvVaw3MnkgK0sKTHX7t5pvECIT5&opi=89978449
Lanzar sd82 input output plug layout
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwi8krnznueCAxWxrokEHT0iBfoQFnoECA4QAQ&url=https%3A%2F%2Fwww.manualslib.com%2Fmanual%2F577337%2FLanzar-Sd82.html&usg=AOvVaw1NvtQPbnDX49X9-I6oRe-J&opi=89978449
