20 Most Recent
ATI Acer Aspire One 722 Netbook Motherboard W/ Amd Fusion C50 P1ve6 Mb.sft02.001 Questions & Answers
How to remove battery
You should remove the battery pack first then open all the cover panel to expose the battery, if your speaking of the CMOS battery and not the battery pack.
Screen is displaying check cable connections no
1. operating system corrupted, repair/ reformat1. your dvd/cd drive or HARDDISK are not connected properly try to remove them the place it on again.2.harddisk/ discdrive or drive either one are faulty condition..hoe this solve it..
How do I unfreeze my keyboard without shutting down completely? why does this happen at all?
you might have to many programs trying to or accessing the internet at the same time
scroll to bottom toolbar (bottom of screen) right click select task manager
applications you will see whats running you might have a virus
if you see anything you dont need running select end now and you might uninstall that specific
program if you or computer does not require it to run and
some unnecessary programs that could be jamming up your computer
also under processes see what is ticking over in the background again if you see something you
dont need to be running select end now and users you will see who is using your computer
you might need to add more computer ram
if you're not sure if a module is right for your system use the
Crucial Memory Advisor tool for a list of guaranteed compatible modules.
when purchasing any ram you should always ask if they can guarantee compatibility first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
hope this helps
Does anyone have a downloadable recovery file for an Acer Aspire 722 Netbook.
not sure what a downloadable recovery file you are referring to or what its related to to
you could run the chckdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps you
HOW TO CHANGE SCREEN SAVER
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settingsalways click APPLY after making any changes
hope this helps
My HD 4850 fan is
Your heatsink fan on the graphic card is failing and the motor is going down hill, now saying it has completly stopped..,.. that means the fan motor is done for and need to be replaced to avoid further damage to your graphic card. Would reccommend you not using your graphic card until a new heatsink fan is replaced otherwise you can fry your GPU and suffer a complete loss.
My graphics card will not
How did you get your drivers and graphics? Did you install the whole package? What is the Asus model #? How much Ram do you have? I'm going to do a little research but let me know what you have.
Dave
HIS radeon HD 6750
Are you certain that your mainboard is PCIE 2.1 and not PCIE 2.0?
PCIE 2.1 cards like yours will not work on a 2.0 mainboard (2.0 cards will work on a 2.1 board, however) If this is the case, you will need to get a compatible card.If this isn't the case, have you tried this card in a different PC? It could also be that the card has a problem.The last possibility is that there are power issues. A couple of possibilities:
- An external power connector (6-pin PCIE direct power to the video card) is unplugged. Check and re-test.
- Your power supply (PSU) doesn't provide enough power to your graphics card & the rest of your system. Check your PSU's specs against the specs for your card. HIS recommends a minimum 450W PSU, and I would recommend a good quality Antec, Corsair, or PC Power and Cooling or Cooler Master product in the 500W range for this card.
- You got a bad card, or else it shorted out, etc. during setup or installation.
Gigabyte vga card d33006
your card is the gigabyte GV-RX195P256D-RH and you can download the drivers from here https://www.gigabyte.com/us/Graphics-Card/GV-RX195P256D-RH#support-dl-driver-vgadriver
