20 Most Recent
Samsung Galaxy Tab 2 7.0 Questions & Answers
Emails not downloading into inbox, but can send them out.
www.pcadvisor.co.uk/.../how-to-set-up-and-use-
email-on-an-android-
tab...
Apr 18, 2011 - Setting up an email account on your Android tablet is not a tricky task, and on our Samsung Galaxy Tab it is extremely straightforward. But you ...
android.stackexchange.com/.../new-
emails-
not-showing-up-in-g
mail-app
Aug 2, 2013 - I have 2 different Android devices: a Samsung Galaxy Reverb ... I have to manually change from Priority Inbox to Normal Inbox (or vice versa) in order for the new emails to show up in my list. ... Why does the new Gmail address not show on the Samsung tab 2 version 7.0? ... Turn PS3 Slim into Linux server.
What to do if my galaxy wont charge
At this level of charge their is not enough to start the boot process , if it doesn't charge at all their may be a fault with the Battery cell , however i had a similar issue, just leave it for a while, if their is still no indication that its charging or it wont turn on their could also be a problem with the Start Button
How to force Samsung Galaxy Tab to shutdown
1.There is no "force shutdown" as far as I know, but you can force a reboot by holding down the power button for about 15 seconds.
2.No force shutdown for galaxy tab, but you can use this trick.
- Plug the charger into your galaxy tab.
- Hold down power button for 10 seconds, and wait to reboot.
- After that, the screen will be change with charging battery.
- Plug off your tab, and it will be shutdown.
- For Tab S and Tab A
Should work with 8.4 or 10.5
6.Hold the Power button, Volume Down button, and Menu key for 10 seconds. You will enter download mode, simply press the volume down button to restart tablet.
After reboot, you tablet should perform as normal
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
