20 Most Recent Dell Inspiron N5040 Black New Questions & Answers
Dell Inspiron N5040 with APTIO BIOS version A03, Service Tag BGS2GR1, ESC 24959208781. The APTIO setup utility is locked and the password is unknown, with the boot device set to Network PXE boot and i
I can't find a decent manual for your computer but there will be 2 pins on the motherboard that will say BIOS Clear. Short these 2 pins and turn the computer on. This is the only way to bypass the BIOS password. This operation will clear the BIOS and reset to factory defaults. After the BIOS is cleared, turn the computer off and take off the short.
3/16/2015 9:22:42 PM • Dell Inspiron... • Answered on Mar 16, 2015
Hello i have my laptop dell n5040 xp win installed also dowload idt high defenition audio but still audio sound not working what did to install i dont understand. please help
Completely remove whatever sound drivers you do have installed, restart, download this: http://ftp.dell.com/audio/R302718.exe Once downloaded install the sound driver I have provided the link for. If it still doesn't work, please post back here with your DELL service tag. This can usually be found on one of the labels on the underside of the laptop. I may be able to help further if you can provide that information.
3/25/2014 4:13:47 PM • Dell Inspiron... • Answered on Mar 25, 2014
My dell inspiron will not turn on wifi,why
Fix Driver Solution In Windows-Start-Control-Panel-Device Manager then search through the list for the element of distress. If it's Audio, it is in the Sound-Video-Game Controllers whereby left clicking on that section will open up a window indicating your electronic devices. A video Camera-Sound Source may show up and if you Right Click on that line you get a message Update Software? You will get another option the Search On-Line Note-you must have internet access for this feature- and say yes, and allow a search to ensue. If you have the Best Driver installed a message stating so will appear- if not you will get an updated driver and it will be installed for you automatically. The other method is to go to the Manufactures Web Site and Support area. Input the necessary data re Model, etc. and look for Drivers. Update ALL new drivers at the same time and install them accordingly.
1/20/2014 9:38:13 PM • Dell Inspiron... • Answered on Jan 20, 2014
My Dell N5040 has no power. When you hook charger
have you try without battery in? in case check the voltage of the power adapter with a multimeter.
12/2/2013 5:05:10 PM • Dell Inspiron... • Answered on Dec 02, 2013
I cant use my webcam on my loptop
USE DELL WEBCAM CENTRAL OR MANY CAM TO USE
11/10/2013 10:43:33 AM • Dell Inspiron... • Answered on Nov 10, 2013
I have a Dell N5040 that has no power. When you
this is problem with mother boardtry thisremove all power connectionsremove batterypress and hold power button for 30-40 secondsand just plug power connector with out batteryif it power on go to bios and restore defaltstry to are three timesor chaing mother board
11/10/2013 10:18:10 AM • Dell Inspiron... • Answered on Nov 10, 2013
Inspiron n5040 wifi on off
use the function keys
11/3/2013 5:03:41 AM • Dell Inspiron... • Answered on Nov 03, 2013
I have a inspiron N5040 with windows 7 When I turn on it goes to windows recovery screen. I followed the repair(recommened) it will eventually bring up a blue screen with a cursor but no way to log in
Try installing on top of its self. It may create another directory and rename the original Window (old). This however will cause you to lose your settings like installed apps and documents. They will be in the OLD folder, but not readily accessible on the new install.
6/11/2013 10:15:15 PM • Dell Inspiron... • Answered on Jun 11, 2013
Administrator access being denied
Go to Control Panel and check you account / login under Users. If you are not a Administrator, you will have to log in with an admin account and make your regular account an admin.Just in case you are a admin already, some programs require you to right click and Run As... You can also lower the User Access Control. Again in Control Panel under Action Center.
1/30/2013 11:35:17 PM • Dell Inspiron... • Answered on Jan 30, 2013
Audio service is not runing
which operating system you are using? try to uninstall audio driver and then reinstall. if does not work , try updated version of the driver and if that too does not work, reinstall operating system and reinstall all drivers.
1/23/2013 3:25:53 PM • Dell Inspiron... • Answered on Jan 23, 2013
My right external speaker produces funny sounds
if membrane is broken ear has wrong circulation, you can try put silicone on it if you see where
12/13/2012 11:13:35 PM • Dell Inspiron... • Answered on Dec 13, 2012
Dell inspiron n 5040 turns off randonly only had it for two months new out of the box
If you want to recover your files, then try to use it over a lap top cooling base. And then take it back to store. They will replace it.
10/15/2012 4:01:16 PM • Dell Inspiron... • Answered on Oct 15, 2012
Cant find SSID code for internet
You need to log into your wireless router or modem using your laptop you will find the ssid codes in there. Are you using a router or modem and what brand is it?
9/23/2012 1:14:49 AM • Dell Inspiron... • Answered on Sep 23, 2012
Dell N5040 touchpad
Is there the option to uninstall? If so, try this, although it may only be a temporary fix because if you're using windows 7, it will automatically detect and install upon restart, although you may disable the automatic installation in CP
8/7/2012 3:21:02 PM • Dell Inspiron... • Answered on Aug 07, 2012
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
1/29/2024 9:26:36 PM • Dell Computers &... • Answered on Jan 29, 2024
2answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
1/16/2024 8:34:33 PM • Dell Computers &... • Answered on Jan 16, 2024
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
My dell laptop i5 does not recognize the external ac source
I would try another power supply and plug that in.
1/5/2024 9:01:17 PM • Dell Computers &... • Answered on Jan 05, 2024
Dell Inspiron N5040 Black New Logo
17 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
  • Computers & Internet
