20 Most Recent Tecnik 24 in. TKD795/3 Built-in Dishwasher Questions & Answers
Water has stopped going through my Dishwasher!
salt tray does have water in there its supposed to have. its probably the magnetic switch on the mains water line in the dishwasher these can go, it can also be a clogged inline filter this will stop water getting through and is located in between the water line and the unit, removing the the pipe from the back will let you see this. it can also be the main switch on the motherboard as these can go as well and will need replacing but i would check the filter first.
1/4/2018 5:15:19 AM • Tecnik 24 in.... • Answered on Jan 04, 2018
Bosch dishwasher recall
hi there. this is all i could find. Contact details Teknik Office Ltd West One 63-67 Bromham Road Bedford MK40 2FG Tel: 01234 328804 Fax: 01234 342446 Email: [email protected] LinkedIn this link will give you more info. Teknik Office Contact Us
12/12/2017 9:54:30 PM • Tecnik 24 in.... • Answered on Dec 12, 2017
It starts but then seems
The reason for the whurring sound is that the water pump is trying to empty the drum first before letting in the new water cycle, I would check your outlet water pipe for any obstruction first by blowing down the pipe to check to see if there's a blockage, with the machine off of course this is of course only a suggestion but I hope it helps eric
11/16/2017 8:08:31 AM • Tecnik 24 in.... • Answered on Nov 16, 2017
Dishwasher retaining water
Is your drain hose routed correctly? It should loop up higher and then go down to the drain connection under sink
11/7/2017 12:35:31 AM • Tecnik 24 in.... • Answered on Nov 07, 2017
0answers
How do i get to the inline heater, the base is a moulded plastic base
pull it out and flip it upside down
7/11/2015 7:58:01 PM • Tecnik 24 in.... • Answered on Jul 11, 2015
My dishwasher will start its wash progame and get stuck when it pumps the water out and the pump will still run
There is a leakage in the dishwasher and the flood switch triggers during wash. This causes the pump to operate and continue to run as the flood switch remains switched. Best to find the source of leak either from door seal or drain hose.
7/31/2014 12:29:09 PM • Tecnik 24 in.... • Answered on Jul 31, 2014
2answers
I need to remove the furniture door off my integrated dishwasher
I have the same problem.I need to take off the door from the integrated dishwasher.I can see a possible screw on the either side of the door but difficult to visualise this to find out what kind of screw it is.
Can someone advise me regarding the method of take the door off the integrated dish washer.
Paul
7/21/2014 9:47:28 PM • Tecnik 24 in.... • Answered on Jul 21, 2014
0answers
0answers
No power
Be the first to answer 4/7/2014 7:30:57 AM • Tecnik 24 in.... • Posted on Apr 07, 2014Be the first to answer
0answers
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
153 questions posted
Top Tecnik Dishwashers Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
ADMIN Andrew
ADMIN Andrew
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Tecnik Dishwashers
  • Tecnik Dishwashers
Most Popular Question
dimensions tecnik 795 2
  • Dishwashers
