20 Most Recent
Intel Desktop Board D815EEA2 (BOX815EEAA2) Motherboard Questions & Answers
Hi the pc does not
Restart your computer
During the boot process you
will see on the screen to press a certain key to enter setup
Press and hold that key
during the boot up process to enter BIOS you can load failsafe
defaults or load optimized defaults
,press escape then press f10 to save to cmos to restartthis is the boot sequence first boot device floppy IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
Hope this helps
When i start my pc
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
My computer was installing windows,
This may due to your system SMPS may having the problem. Check whether SMPS is powring ON. If yes then go to BIOS mode and check whether HDD has been detected and then reinstall the OS may resolve your problem. Else need to repair/replace the SMPS will resolved your problem.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
I hav ejust purchased a new lg gh22 dvd writer. It
hi,
Is the hard disk drive is in secondary slave? If yes, change it to master and your dvd is into slave. Refer to the jumper settings at the back on the drive. If not work, your bootable disk may defective. Try other a botable disk.
Best regards,
geloaa
D815E video failure
If it's the bios settings, you could try resetting it by removing the small battery on the motherboard (Looks like a watch battery). Make sure the computer is unplugged before you do that, of course. Keep the machine unplugged for up to 48 hours (It can last sometimes, don't ask me why, but it's happened to me before) and try again.
What does it mean when different RAM is in
try to insert only one RAM then boot, but if doesn't try the other one then boot again but if the two doesn't work try raplacing your video card with a new one for testing but then again if it doesn't work check if your monitor is working maybe you have a bad monitor good with that...
Problem with hdd
try to replace the memory (RAM) from the mainboard or try to tighten the memory from its slot.
Intel VGA Built in #N68011NW800637 MP25
Hii, you can download all the driver of your Intel motherboard at
http://downloadcenter.intel.com/default.aspx?iid=gg_work+home_dowloads#
Go this site and at the left hand side, go to the desktop board and select your exact motherboard model. After selecting the model you just download the driver as per your requirement and install it.
