20 Most Recent Actiontec GT704WG Wireless Router (gs583ad3-01) Questions & Answers
4answers
Router configuration
i sujject you learn CCNA - cisco certified network associate course ware .. then you can configure most of the routers with slight syntax changes
good luck
2/1/2019 5:38:54 AM • Actiontec... • Answered on Feb 01, 2019
0answers
Am I getting high speed thru my actiontec gt704wg
It depends on your DSL connection- technically anything above 56k is "high-speed internet"- if you are concerned about the speeds you are getting, contact Verizon tech support for further assistance- you could have an issue with your connection, and they would be the ones able to setup for a technician to come out/ have the maintenance office repair the connection I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
3/6/2017 11:37:59 AM • Actiontec... • Answered on Mar 06, 2017
Hi I want to know
Are you on Consumer Verizon DSL? Fair warning if you are using Business Static- the Actiontec is a poor choice due to issues working on a static IP circuit. - I'd use a 6110 and a third party router! However, by default, the only thing you would need to do to setup the modem is go through the activation page when you plug the modem in. If you require an user name and password, it would set that up. Bar any problems, you can contact Verizon technical support since the Actiontec Gateway is fully supported. I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
3/6/2017 11:32:28 AM • Actiontec... • Answered on Mar 06, 2017
2answers
Verizon GT704WG DSL Modem wants me to install software
If my memory serves me, I didn't install the software for my Actiontec modem/router combo. I call Verizon and told them I refused to install the software and they helped step me through getting rid of this garbage. You should never have to install software to get a modem or router to work as any software the comes with it, is simply used to provide easier configuration.
Since I couldn't find anything about bypassing this software, I would suggest contacting Verizon directly. Their technical support should be able to assist you.
8/24/2015 4:14:28 AM • Actiontec... • Answered on Aug 24, 2015
INSTALLING ACTIONTEC WIRELESS ROUTER/MODEM
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
9/2/2014 6:37:36 PM • Actiontec... • Answered on Sep 02, 2014
FORGot passphrase for router
you can factory reset the router and then it should allow you to create a new password. Hold reset button in back down for 12+ seconds. be advised this will reset all router settings back to factory defaults.
8/13/2014 4:23:21 PM • Actiontec... • Answered on Aug 13, 2014
I have no WI FI in my house and my grand children are comming over and need the internet for minecraft
How do you know that you do not have wifi in the house? that router is a wifi router, do you have any wireless devices that you can try to connect with before your grand kids come over? Like I said the router you have is a wifi router so when the grand kids come over they will probably be able to connect, they will probably just need the SSID and WPA2 key that can be found on a sticker on the router.
8/13/2014 4:14:42 PM • Actiontec... • Answered on Aug 13, 2014
Why are all lights out router
1. not plugged in 2. bad outlet 3. the on/off switch on the back is set to the off position 4. bad power supply unit if it doesn't turn on after checking all this then you need a replacement.
8/13/2014 3:30:41 PM • Actiontec... • Answered on Aug 13, 2014
My youtube videos are buffering
What device are you using? smart TV? are you connected via wifi or lan ethernet cable?
8/13/2014 3:17:47 PM • Actiontec... • Answered on Aug 13, 2014
3answers
Power Light Is Red, Internet Light Is Green, Other Lights Off
Check cable connections.
Try unplugging router from power for five minutes.
If that does not work call Internet Service provider to check if there is a problem with their server.
3/5/2014 2:24:59 PM • Actiontec... • Answered on Mar 05, 2014
Error "virtual server add error" failed. stats: 1
I had this error. There was an old rule for an old device that was no loonger connected. If a device that has a rule is not connected, no information will show up telling you there is a rule. But it already exists and is hidden. The rule will only show up when the device is connected. But the rule is active wether or not the device is connected. The only .I found to fix this is to reset the router to defualt settings, this will remove the old device and it's tules from memotry.
2/26/2014 10:28:18 PM • Actiontec... • Answered on Feb 26, 2014
Password reset
Hey; While the router is turned on, look in the back and locate the reset button. Press and hold for 10 to 15 seconds and then release. The router should reboot and return to factory settings. Go to the router page and use the fallowing to log in. User: admin Pass: admin You can re-enter all router info after login.
2/18/2014 12:32:25 PM • Actiontec... • Answered on Feb 18, 2014
Security key
Look on the underside of the Router. it is usually marked on there. look for a WEP or WPA with a number.
7/24/2013 8:20:48 PM • Actiontec... • Answered on Jul 24, 2013
Actiontec GT704WGB from Verizon is working through Earthlink yet Verizon still thinks it is providing service and want to set up my "account"
Sounds like you have Verizon software on your computer. The router has nothing to do with that. Go into control panel > add remove programs and remove the Verizon software.
2/17/2013 4:52:42 PM • Actiontec... • Answered on Feb 17, 2013
Cannot connect to 192.168.1.1 to set up wireless in my router
If you fail after ping your IP address then it may be problem in your physical connection,so you should check connection like:check cable modem status light. If it is solid green, it indicates that your cable modem has a good connection. If the light is off, check modem's physical connection.Verify that the Internet light on your wireless router is solid or blinking green. It indicates a good connection and correct wiring. If the light is off, check the Ethernet wire's connection between your modem and router.May be it can be cause of Incorrect wireless network setup & configuration. Recheck and correct the Ethernet connection between your PC and the router device.***If you need any kind of technical assistance you can contact support cell at here
2/1/2013 5:50:05 AM • Actiontec... • Answered on Feb 01, 2013
How can i set up the router?
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
1/29/2013 7:29:57 AM • Actiontec... • Answered on Jan 29, 2013
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
330 questions posted
Top Actiontec Computers & Internet Experts
Jesse Walters
Jesse Walters
NOEL
NOEL
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Actiontec Computers & Internet
Most Popular Question
error virtual server add error failed
  • Computers & Internet
