20 Most Recent
Icom IC-M505 - VHF/DSC Marine Transciever Questions & Answers
Icom ic-m505 refuses to scan. In the setup menu, there is nothing visible about dual or tri- scan!!
DUALWATCH/
Description
Dualwatch monitors Channel on another channel;
Tri-watch monitors Channel 16 call channel while receiving another is convenient for monitoring operating on another channel.
DUALWATCH/TRI-WATCH SIMULATION
Call channel
Dualwatch
Tri-watch
If a signal is received on Channel 16, Dualwatch/Tri-watch
pauses on Channel 16 until the signal disappears.
If a signal is received on the call channel during
Tri-watch,
Tri-watch becomes Dualwatch until the signal disappears.
To transmit on the selected channel during Dualwatch/Triwatch,
push and hold
[PTT]
Operation
q
Select Dualwatch or Tri-watch in Set mode. (p. w
Rotate [CHANNEL] to select the desired operating e
Push [DIAL•DUAL/GRP] for 1 sec. to start Dualwatch or
Tri-watch.
•"DDDU
UUA
AAL
LL
66" appears during Dualwatch; "
T
TTR
RRI
II
66" appears during
Tri-watch.
A
beep tone sounds when a signal is received on r
To cancel Dualwatch/Tri-watch, push
[DIAL•
DUAL/GRP]
again.
[Example]:
Operating Tri-watch on INT
Channel 25
Tri-watch
starts. Signal is received on call channel.
25W25W
INTINT
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
TELEPHONETELEPHONE
BUSYBUSY
25W25W
INTINT
CALLCALL
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
INTLINTL
Tri-watch resumes after the
Signal received on Channel
signal disappears.
16 takes priority.
25W25W
INTINT
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
TELEPHONETELEPHONE
BUSYBUSY
25W25W
INTINT
DUPDUP
TAGTAG
TRITRI
1616
3434°
34.506N34.506N
123123°
23.236W23.236W
UTCUTC
1212:00:00
TELEPHONETELEPHONE
More user manuals on
ManualsBase.com
If not understand mail me
[email protected]
Why is my icom ic-718 hf radio stuck in tx mode?
It can be a few things but first try resetting your CPU, while your transceiver is off, hold down the UP & DOWN buttons simultaneously then turn the transceiver back on, now it should be reset to the factory default settings
11/29/2023 11:26:24 PM •
Icom Radio...
Answered
on Nov 29, 2023
ICOM A210 aircraft radio transmits but is not recieving
The RX light should light up when receiving a signal. It may be your squelch setting is too high. Push the VOL knob until it enters the squelch setting, then set the squelch so it just cancels noise. If still not working you could have a wire broken in connector from headset that plugs into the radio.
Remote key pad for IC-7610, I press a button and just get a beep like no memory is loaded, but memories on screen work.
If you're hearing a beep when pressing a button on the remote keypad for your IC-7610, it's possible that the keypad is not programmed correctly or is not communicating with the radio properly. Here are a few troubleshooting steps you can try:
- Check the connection: Make sure the remote keypad is securely connected to the radio's remote jack using the supplied cable.
- Check the settings: Make sure the remote keypad settings on the radio are configured correctly. Press the MENU button on the radio, select "Set" and then "Remote Operation." Check that the "Remote Type" setting is set to "IC-7610" and that the "Remote Address" matches the keypad's address.
- Check the keypad programming: Make sure the buttons on the keypad are programmed with the correct commands. You can check this by pressing the MENU button on the radio, selecting "Set" and then "Function Keys." The functions assigned to each key should be displayed on the screen. If they are not, you can program them by pressing and holding the F key on the keypad and then pressing the button you want to assign a function to.
- Reset the radio and keypad: Try resetting the radio and keypad to their factory settings. You can do this by pressing and holding the POWER button on the radio until it turns off, and then pressing and holding the FUNC button and the ENT button on the keypad while turning the radio back on.
If none of these steps work, it's possible that there is a hardware issue with either the radio or the keypad. You may want to contact the manufacturer's customer support for further assistance.
Model 718. Why is CW mode kaput?
There are a few possible reasons why your radio might not be transmitting in CW mode. One possibility is that the keyer chip has gone bad. Another possibility is that there is a problem with the power supply. If you have a multimeter, you can check the voltages to see if they are within specification. Finally, it's also possible that there is something wrong with the antenna connection. Make sure that everything is securely connected and that there are no loose wires. I hope this helps!
