20 Most Recent
Standard Horizon Hx300 Compact Floating Handheld Vhf Radio unpublish Questions & Answers
Standard Horizon vhf stuck at screen message "EE-PROM initializing"
It sounds as if the radio needs to be reprogrammed. It could also be a cold solder joint causing the problem but my guess is the radio needs to be reprogrammed. If you purchased this used, it is very likely that the frequencies were removed prior to the sale. OR, the EEPROM was removed to make surre that the frequencies were removed. It's typical practice for radio shops to do this to prevent unauthorized use on radio frequencies.
Where is the taxi radio wiring taken from the battery or fuse box?
Usually from the battery, but it all depends on the installer. Most of these istalls have been poorly done by people that don't have a clue. ower should be taken directly from the battery with a fuse at the battery terminal. This will reduce electrical noise heard on the radio.
Realistic scanner police codes
I recommend RadioReference.com, they have detailed lists from all over the United States. In addition to frequency lists, they also include live audio, HAM radio lists, licensing information and a lot more.
4/4/2024 5:32:44 AM •
Radio...
Answered
on Apr 04, 2024
