20 Most Recent SanDisk 2GB Sansa c250 Series MP-3 Player Red SDMX7-2048R-A18 Questions & Answers
How i Regord music from cd-pleyer
When you want to record music on your MP3 player, you have to use a computer in between. Use the sound card in the computer, to connect the CD player, or even better, put a CD in the CD / DVD player / burner of the PC. Then you need a program to extract the music from the CD to the PC in MP3 format. You can download the program for free here: Audacity Free Audio Editor and Recorder Once the music is on the PC you can add it to your MP3 player, by connecting the player. Before you connect a MP3 player, you have to install a program so it can communicate with the computer. The software should be on a disk that came with the MP3 player, or you can download it from the website the MP3 players manufacturer.
2/3/2015 7:51:19 PM • SanDisk 2GB... • Answered on Feb 03, 2015
SanDisk Sansa C240 1 GB MP3 Player only shows half empty battery picture on screen and wont turn on. So it needs fixing.
Question edited for a lot more clarity. Question moved from Misc to model category. Replace the internal Li-Po battery, but try a reset first. https://www.google.com/search?q=sandisk+sansa+c240+battery+replacement If your Sansa player is freezing, not charging or not turning on, the first thing to try is a reset of the unit. This will normally clear any temporary condition that may cause the player to freeze or not shut off completely, it's a bit like when your PC crashes and you need to re-start it to clear the error. Dec 28, 2020
My Sansa MP3 player has stopped working or charging
Sansa Clip Won't Charge - iFixit
iFixit https://www.ifixit.com > Answers > View > Sansa+Clip... Feb 15, 2021 - I found an older Sansa Clip which will power on when connected to a USB charger or to the computer, but it won't boot up or hold a charge. 1 answer · 1 vote: Hi, Sounds as though the battery has failed and needs to be replaced. I couldn't find a battery replacement guide for a Sansa Clip but here's a video ... How to replace dead battery in Sansa Clip mp3 player? Oct 1, 2010 Why is my clip say tranferring and not charging Jan 16, 2017 Where can I find a new battery? - Sansa Clip Plus Mar 27, 2017 My MP3 player won't turn on once I remove the charger. Aug 3, 2015 More results from www.ifixit.com
Sansa Clip Battery is not charging - SanDisk Forums
sandisk.com https://forums.sandisk.com > sansa-clip-battery-is-not-... Jun 4, 2008 - You can try to charge the device first, to make troubleshooting easier. Unplug the device, then select Settings, then USB Mode, then MSC. Now ... SANSA CLIP ZIP NOT TURNING ON, NOT CHARGING Feb 27, 2013 Sansa clip won't charge - SanDisk Forums Jan 4, 2010 SanDisk Sansa Clip+ doesn't charge, doesn't turns on or ... Nov 2, 2016 Sansa Clip Zip battery won't charge, goes straight to song ... Nov 28, 2014 More results from forums.sandisk.com
3/18/2023 11:36:26 PM • SanDisk Sansa... • Answered on Mar 18, 2023
Sansa m240 MP3 player. Can't replicate features on a new Sansa m240 mp3 player that I had on an older Sansa m240 mp3?
Is your firmware 5.1.11? That appears to be the lastest. One issue is that software and firmware can't usually be rolled backwards.Contact Western Digital / Sandisk direct to check you have the most up to date Software package on it.https://www.westerndigital.com/support/international-phone-numbershttps://www.google.com/search?q=sansa+m240+mp3+update+software+download..
3/22/2022 2:30:49 PM • SanDisk Sansa... • Answered on Mar 22, 2022
How to unlock a prison sandisk sansa mp3 player
Here is a link on how to do it: How to Unlock Federal Prison Sansa MP3 Player
5/14/2017 9:47:24 PM • SanDisk Sansa... • Answered on May 14, 2017
2answers
Dropped in soapy water it worked. Did it again stopped working. Can it be fixed. Tried the rice method.
If dried out and still not working it is not worth fixing, even if possible - cost is probably under $50 new, less used. I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
5/23/2016 12:03:26 AM • SanDisk Sansa... • Answered on May 23, 2016
Is there a way to deinstitutionalize the Sandisk
there is no (consumer) known way for you to do this on your own. Pay the 25 bucks and send it in so they can do it. They have these things locked down pretty tight; nobody to my knowledge has found a way to circumvent it. my source of research is http://forums.sandisk.com/t5/Sansa-Clip-Sansa-Clip/deinstitutionalize-or-factory-restore/td-p/301697/page/2
3/28/2016 4:02:15 PM • SanDisk Sansa... • Answered on Mar 28, 2016
0answers
How do I unlock sandisk mp3 player
Press the slider switch down to lock and press up and hold a few seconds to turn on (and unlock).
8/7/2014 3:45:40 AM • SanDisk Sansa... • Answered on Aug 07, 2014
Won't stay on
That is a glitch in the firmware, nothing you can do about it except remove files. You can flash RockBox firmware on it and that'll fix the problem.
5/20/2014 7:37:02 PM • SanDisk Sansa... • Answered on May 20, 2014
SanDisk 2GB Sansa c250 Series MP-3 Player Red SDMX7-2048R-A18 Logo
3 questions posted
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
regord music from cd pleyer
  • Audio Players & Recorders
