20 Most Recent Tascam DR07mkII DIGITAL RECORDER Questions & Answers
How do I trim the tracks after Ive recorded them on my tascam dr07)
http://audacity.sourceforge.net/ That might help you out here, plus it's free. Just copy/import the file you want to edit, and trim away the unwanted parts.
3/7/2015 6:37:58 AM • Tascam DR07mkII... • Answered on Mar 07, 2015
The CD tray on my Tascam CD-A500 CD/Cassette combo will not open.
I understand that your CD tray on your Tascam CD-A500 CD/Cassette combo will not open. Here are some possible reasons why this might be happening and what you can do to fix it:
  • The CD tray may be stuck. If this is the case, you can try to gently pry it open with a flathead screwdriver. Be careful not to damage the tray or the unit.
  • The CD tray motor may be broken. If this is the case, you will need to replace the motor. This is a relatively simple repair that can be done by most people.
  • The CD tray sensor may be faulty. If this is the case, you will need to replace the sensor. This is a more difficult repair that should be done by a qualified technician.
If you have tried all of the above and the CD tray still will not open, you may need to contact Tascam customer support for further assistance. Here are some additional tips to help prevent your CD tray from becoming stuck in the future:
  • Do not force the CD tray to open or close.
  • Be careful not to drop or damage the unit.
  • Keep the unit clean and free of dust and dirt.
  • If you are not going to use the unit for an extended period of time, unplug it from the power outlet.
I hope this helps!
5/13/2023 5:56:58 AM • Tascam Audio... • Answered on May 13, 2023
TASCAM 122 MKIII professional, rack mounted, 3 head cassette deck. Problem / no sound!
That is an electronics issue, so you need test equipment. You can look for disconnected wires from when you replaced the gear. https://www.google.com/search?q=tascam+122+mkiii+no+sound+output ..
4/10/2023 11:29:28 PM • Tascam Audio... • Answered on Apr 10, 2023
Tascam 2488 Neo doesn't work on G and H knobs on trim.
Dealer Service if the knob pots have physically failed. Made by Sanyo. https://www.google.com/search?q=Tascam+2488+neo+doesn%27t+work+on+g+and+h+knobs+on+trim ..
3/26/2023 6:38:19 PM • Tascam Audio... • Answered on Mar 26, 2023
2answers
Is there a hard factory reset for the Tascam DP-24SD? Mine powers on but the source and record lights are not working right.
Hi, yes there is. I saw that using the menu presences to find the initialize option and activate it is the way to run a factory reset on your machine. So, you can start with this first. Otherwise, please reference the manual. Thank you.
11/3/2022 2:46:13 AM • Tascam Audio... • Answered on Nov 03, 2022
Please I have a Tascam 2488neo hard disk recorder. It's bringing out the error message Code 04. SDRAM Initialize Error. What do I do now?
Just failed or bought it dead or ran 1day and died.(history matters)BY FAMOUS MAKER TEAC. mark 1 or MARK II modeL?TELL WHAT YOU ARE DOING ON THIS complex system just before the failure.Just simply turned on? or burning dvd-r or reading media. ? last page USA if is says contact TEAC AMERICA, INCa coin cell is inside my guess, and is long overdue if there.15 years old is near 2 times the life span of a coin cell battery.it has 80GB HDD that can very easily be badand a SDRAMand no SD cards, of any kind. ,USB port allows transfers to a PC>the manual only states thisbattery pack or batteries installed)https://tascam.com/us/product/2488neo/downloadthe SDRAM does not plug in like PCsso is soldered down. make sure all batteries are good firstand if yes, make sure the PSU board is not bad with classic thenCAP Plague. error bad caps. . it is at least 2010 old. lots of reviews then and any batteries here are no good that old, and HDD can be bad, ask how to test in on a PC.so what is bad.1: batteries.2: CAP plague caps leaking bulged out. (wiki it)_!3: HDD bad. if not bad, best is to clone it now for later when it does die4: Sdram bad (only if power surged AC or lightning hits.5: PSU bad see #2
8/5/2022 2:13:35 PM • Tascam Audio... • Answered on Aug 05, 2022
Tascam Professional Recorder lights up "needs repair!"!
I am by no means an expert, but is there a possibility that the recorder requires repair ?
12/31/2021 6:32:27 PM • Tascam Audio... • Answered on Dec 31, 2021
Tascam DP 006 freezing up
visit https://www.bhphotovideo.com/lit_files/90177.pdf
9/25/2021 5:04:19 AM • Tascam Audio... • Answered on Sep 25, 2021
I have a tascam dp-01 that stopped working.can i put the hard drive disc into another dp-01 without losing my songs?
It should work I would think as it uses the same OS. I suspect the hdd has issues it the system doesn't complete its boot.
9/4/2021 7:12:42 AM • Tascam Audio... • Answered on Sep 04, 2021
I have a Tascam 688 mini studio, its 8 tracks on a cassette tape, I have just replaced the capstan belt and now the tape speed is way too fast even when I'm in variable mode with the speed turned all
It is possible the control transistor in the capstan motor has shorted due to age. There is a control in the deck for calibration of speed but then you need equipment and a MXT111 test tape to set the speed. So you may need a new Capstan motor or maybe just an adjustment- hard to say exactly without me looking at it- yes, I still fix them. I have been doing them for about 45 years and I worked at Teac as a Lead Tech in Arlington Heights IL.
6/29/2021 1:37:26 PM • Tascam Audio... • Answered on Jun 29, 2021
Tascam 222 mkIII
What is your question, please? Comment menu can be used to add information to your question. Free online manual at the internet link below: https://tascam.com/downloads/tascam/342/CC-222MK3_manual.pdf
7/6/2020 11:11:15 PM • Tascam Audio... • Answered on Jul 06, 2020
How to fix tascam
https://www.youtube.com/watch?v=yaVE-39gS4g https://www.scribd.com/doc/229500599/Tascam-DM-3200-Service-Manual
4/16/2020 5:49:27 PM • Tascam Audio... • Answered on Apr 16, 2020
How do i start the AUTO repair program for my tascam 2488 mk2
I don't see any mention of an "Auto repair program" in the manual.
9/27/2019 8:22:38 PM • Tascam Audio... • Answered on Sep 27, 2019
Tascam DR07mkII DIGITAL RECORDER Logo
1 questions posted
Top Tascam Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Tascam Audio Players & Recorders
Most Popular Question
trim tracks after ive recorded tascam
  • Audio Players & Recorders
