20 Most Recent
Linksys PCMCIA Network Card PCMPC100 Network Adapter Questions & Answers
No association with access point
hi
is the access point WEP enabled? or is it public? as long as you are able to detect the access point, try and edit your profile to which you can connect.
if it is a WEP enabled access point, you should have a passphrase key to access it.
if its public...
try and use this...
http://www.makayama.com/EasyWifiRadar.zip
hope this helps
Lost my cd to my linksys wireless adapter
Just go to LinkSYS.com, you'll end up on Cisco, but don't worry. Go to support and download and then select you model number. Be sure you also have the version, and you will be fine.
Need a driver
It would seem that you posted your concern twice. To your concern, does it look something like the image belwo?
If yes, it is as you posted, a 802.11b Wireless LAN Cardbus Adapter distributed by GetNet Technology Co., Ltd. with model #
GW-9106PC. Pls find driver and manual download from
here.
Hopethis be of initial help/idea. Pls post back how things turned up orshould you need additional information. Good luck and kind regards.Thank you for using FixYa.
Drivers for Ethernet Controllers & PCI Modem
Go to the manufacturer site and search for driver. USB network driver is not compatible with XP, then you have to download latest driver from site. you can try here
www.packardbell.com
or original manufacutere of it
you may give correct details about usb network adapter
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
How to Fix Linksys Router Error 2118?
This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
7/29/2021 11:33:41 AM •
Linksys...
Answered
on Jul 29, 2021
