20 Most Recent
ASUS WIRELESS ROUTER |WL-520G - RT (WL520G) Questions & Answers
Asus wireless router
what kind of connection do you have? and to what?
I assume you have an ADSL(high speed) connection to the internet, and are trying to connect wireless to a laptop or something.
what kind of devices are you trying to connect together? this will help with an answer.
I can't log in to
if you can not remember the password than the ownly thing you can do is a reset (according to manual) than you will be able to log in using default user and password (YOU WILL LOOSE ALL SETTINGS) so you will have to re configure the router...
Have fun!
How to open asus wifi
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
CanĀ“t access 192.168.1.1 (router admin page)
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
How reset my asus router
I had same problem with my asus device. so i called Asus Tech Support At Toll Free Number 1800-585-2494 and they have fixed my problem.
Hope they will help you as well.
I cant reset asus rt-n10e routr
How do i reset my wifi password?
There should be a button on the bottom of the router labeled 'reset'
push it in and the router will reset to factory settings.
( dhcp is usually enabled by default)
the lights for network activity should blink for a few seconds as the
router gets a new ip from the network. you should then
be able to go to 192.168.1.1
and access the router.
some motorola routers use an address in the 10.x.x.x
range
How do I change my password?
Connect to your router preferably with a network cable. login via your browser to http://192.168.1.1 using admin as both the login and password. Once logged in it should give you a message to change the password, but if not, you will easily find the location for making a password change. Just make sure you write your new password down so you can change it on every machine you wish to allow on your network.
Trying to install the Asus WL-520GC wireless
The cd is useful only when you want to install the drivers for using the router through USB port. In your and in most of the cases all you have to do, after the connections, is to start any browser (mozilla, internet explorer, safari e.t.c.), go at the router's page and make all the necessary settings with the web interface. In your router the default router's page is http://192.168.1.1 the user-name is admin and the password is admin.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Can't get login asus wl-520gu page when i type in
Try using http://192.168.0.1 to get to the log in page of your router. The username should be: admin and password is either: admin or (no password). If this does not work, there is a reset button located on the back of your router, press this button and hold it for about 10 seconds while the unit is on, then try going to that address again.
If this still does not work, look on the bottom of your router or on the box which your router came in or the manual that came with the router. Check that you are trying to go to the correct IP Address. It should be located on the router itself, although, the standard IP Address for most routers is 192.168.0.1
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Asus WL-520GC wireless not working....
hi buddy!
first you configure the router to the modem ok
by typing the 192.168.1.1 and follow the instruction ok
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
