20 Most Recent LG 55LM6200 55" Class FuHD 1080p LED LCD Cinema 3D Smart TV - Bund- with BP620 FuHD 1080p 3D BRay Disc Player & AG-F216 Cinema 3D Glasses, FamiPack, 6 Pairs Questions & Answers
Red light flashes 28 times an tv doesn't come on
replace the power supply
12/3/2013 5:08:07 AM • LG 55LM6200 55"... • Answered on Dec 03, 2013
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
3/11/2024 11:43:44 AM • LG Cell Phones • Answered on Mar 11, 2024
How to unlock wheels on LG refrigerator - model LMXS27626S
The wheels have no locks on them. If you want to use the wheels you have to screw in the feet. https://www.google.com/search?q=LG+refrigerator+LMXS27626S.+How+to+unlock+the+wheels ..
2/19/2024 5:38:48 PM • LG Cell Phones • Answered on Feb 19, 2024
2answers
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
  1. Turn the phone off.
  2. Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
  3. When the Factory data reset screen appears, release both of the keys.
  4. Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
  5. Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
  6. Your phone will perform a factory reset.
2/3/2024 11:11:02 PM • LG Cell Phones • Answered on Feb 03, 2024
How to I factory reset a LG Android Phone. I forgot the code to the screen lock
Hi, The link below is a short youtube video showing how to factory RESET your phone....CHEERS.. How To Hard Reset LG G4
2/3/2024 10:59:49 PM • LG Cell Phones • Answered on Feb 03, 2024
5answers
How do I recover phone history from my phone that
When files are "deleted" they are not actually removed from your iPhone, until something else overwrites them. So by saving anything else to them you may have overwritten them. There is a decent chance that you can restore lost data of iPhone though. I've successfully used undeleted plus before to restore iPhone history that were accidentally deleted on my iPhone. Give it a shot and good luck.Read more: http://www.recovery-ipad.com
1/10/2024 1:36:33 PM • LG Cell Phones • Answered on Jan 10, 2024
Plz help my phone LG GS170 its imei 012201001451683 need unlock code
Contact your service provider.
12/30/2023 3:02:29 PM • LG Cell Phones • Answered on Dec 30, 2023
Where does the SIM card go on a LG LS670 phone?
Question edited for clarity and typo. It takes a Micro SD Card in the upper right edge. Page 12 of the Manual shows it. https://www.lg.com/us/mobile-phones/pdf/LS670_%20Optimus_S_UG_1.1.pdf https://www.google.com/search?q=lg+ls670+insert+micro+sd+card ..
11/30/2023 9:43:24 PM • LG Cell Phones • Answered on Nov 30, 2023
LG G7 ThinQ. It won't connect to my Bluetooth touchscreen.
Question edited for clarity. The problem here is not knowing what the 'Bluetooth Touchscreen' is on? This is normally an issue shaking hands to complete the connection. https://www.fixya.com/support/r26362721-pairing_bluetooth_devices ..
11/25/2023 8:05:58 PM • LG Cell Phones • Answered on Nov 25, 2023
MY LG PIN IS BLOCKED. How do I go about it?
Question edited for clarity, I presume you meant LG not 'PG'? It sounds like it is PUK Locked, also known as a SIM Lock. https://www.fixya.com/support/r26056685-phone_asking_puk_code and in simpler terms https://www.fixya.com/support/r26230986-phone_asks_puk_code_ask_another_way ..
11/22/2023 8:56:12 PM • LG Cell Phones • Answered on Nov 22, 2023
3answers
LG LH-T7650 DVD Receiver turned off after I insert a USB drive.
The USB socket is for reading multimedia USB Memory. Your phone has power in it. Not sure how that would work. Page 5 https://manualzz.com/doc/49428761/lg-lh-t7650x-owner-s-manual ..
5/20/2023 1:02:20 AM • LG Cell Phones • Answered on May 20, 2023
2answers
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
  1. With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
  2. Release the Home key and Volume Down key when the Android icon appears.
  3. Follow the on-screen instructions.
4/1/2023 11:47:35 PM • LG Cell Phones • Answered on Apr 01, 2023
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
3/17/2023 12:51:52 AM • LG Cell Phones • Answered on Mar 17, 2023
How come after I take a picture on my LG ENV3, it does not save?
Could be saving to a memory card!
Check settings to see where the photos are being stored!
2/22/2023 11:39:42 PM • LG Cell Phones • Answered on Feb 22, 2023
Lg classic flip phone wont call out or text voicemail now diff carrier
If your LG classic flip phone is not able to call out or send text messages, there could be several reasons for this issue. Some of the common causes are:
  1. Network Coverage: If you have recently switched to a different carrier, it is possible that your phone is not receiving adequate network coverage in your current location. Try to find a location with better signal strength.
  2. APN Settings: It is possible that the Access Point Name (APN) settings on your phone are incorrect for the new carrier. Contact your carrier to obtain the correct APN settings and update them on your phone.
  3. Phone Settings: Some phone settings, such as the network mode, may have changed during the switch to the new carrier. Verify that the settings on your phone are configured correctly for the new carrier.
  4. SIM Card: The SIM card may have become damaged or is not compatible with the new carrier's network. Try inserting a new SIM card from the new carrier.
If none of these solutions resolve the issue, it is recommended that you contact the new carrier for further assistance. They will be able to diagnose the issue and provide a resolution.
2/13/2023 12:31:32 AM • LG Cell Phones • Answered on Feb 13, 2023
3answers
I have an lg sound bar ( las350b) and s-protec shows on the display and I can't use any other function, I turned it off and on and now emergency update mode shows and still I can't do anything.
No part needed. On your mobile phone, search for the music flow bluetooth lg apk, download and install it. You need to do it this way since the app has been discontinued from the Android App Store. Put the device in BT READY mode, it should still let you. Then open the app, press the HELP button then go to Connection problem resolution, your device should pop up here. When you select it it will tell you that the firmware is not supported any more and needs updating. Follow the instructions on screen to update it and you are done. I fixed a LG LAS305B soundbar this way after translating a forum in spanish. This is the one that found the fix: https://www.yoreparo.com/es/audio/home-theater/preguntas/6107507/sound-bar-modelo-lg-las350b-problema-emergency-update-mode This issue is super suspicious if you ask me. You could almost conclude that LG bricked your device intentionally. Hope it will help someone out there. I will post this response whereever i find this issue online.
2/4/2023 11:32:56 AM • LG Cell Phones • Answered on Feb 04, 2023
I need sim unlock code for korean lg cyon sv420
12/26/2022 3:06:46 PM • LG Cell Phones • Answered on Dec 26, 2022
3answers
What is my subsidy password?
The term Subsidy Password is used by Motorola and other handset manufacturers to refer to the 8-digit (or 16-digit code for newer phones such as the Motorola K1) unlock code necessary to remove the operator lock (also known as subsidy lock) from cell phones. You specified your phone is LG,LG Phone ask for Unlock code,but subsidy password request from a Motorola Phone,Ok you can get the Motorola Subsidy Password at Onlinegsmunlock and Unlock the Phone,You need to specify the network it locked now and Country,mobile Phone model....
12/25/2022 2:16:52 AM • LG Cell Phones • Answered on Dec 25, 2022
LG 55LM6200 55" Class FuHD 1080p LED LCD Cinema 3D Smart TV - Bund- with BP620 FuHD 1080p 3D BRay Disc Player & AG-F216 Cinema 3D Glasses, FamiPack, 6 Pairs Logo
3 questions posted
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
LG Cell Phones
  • LG Cell Phones
Most Popular Question
red light flashes 28 times tv doesnt
  • Cell Phones
