20 Most Recent Canon (6981A002AA) for imagerunner 2200, 2800, 3300 Print Server Questions & Answers
6answers
CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
1/11/2023 1:57:01 PM • Canon... • Answered on Jan 11, 2023
2answers
Canon Image Runner 3300. Ii has error code
canon image runner 3300 has error code e000007-0000
10/23/2022 11:34:19 PM • Canon... • Answered on Oct 23, 2022
4answers
Canon ir 3300 error code display e000019-0000
It means that your waste toner box is full.
You can do the next:
On left side of copier, on lower left side you have small cover with screw.With screw driver unscrew it and remove cover. Remowe the waste toner box/container, and clean it, after you removed toner wash it with water and clean the inside and outside of box neck with alcohol to remove the antistatics. Place it back and restart the copier.
5/22/2022 6:08:08 AM • Canon... • Answered on May 22, 2022
Canon ir2520 shown in display network download available
So download the file. it's obviously not set up correctly. http://software.canon-europe.com/products/0010801.asp
10/29/2019 4:54:15 AM • Canon... • Answered on Oct 29, 2019
3answers
E000014-0000
E000014-0000 ir 3300 canon machine solution
9/16/2019 4:14:36 PM • Canon... • Answered on Sep 16, 2019
2answers
What is error code e000014-0000 on canon IR3300
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Rate my response!! Thanks, SF
2/21/2019 2:53:40 AM • Canon... • Answered on Feb 21, 2019
What is this for error
Silly Goose. That is the error code you are getting.
2/4/2019 9:27:00 PM • Canon... • Answered on Feb 04, 2019
3answers
Error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
11/12/2018 4:37:42 AM • Canon... • Answered on Nov 12, 2018
Canon IR 3300 error code E000014-0000
this is fixing drive motor error regards Muhammad Ali [email protected]
9/22/2018 7:19:25 AM • Canon... • Answered on Sep 22, 2018
Canon error E000514-0000, nothing happens when i
Printer Support Phone Number 1-844-804-3954 fix Printer related issue Our Printer Support Phone Number is available 24*7 to help you. We are here provide the solution to every technical problem related to printer. Our printer support team is helping with all of the technical issues. Get in the touch with us at our technical support team for finding the best solutions to all your issue or quarries. If you want to fix your problem dial 1-844-804-3954.
7/20/2018 5:51:10 AM • Canon... • Answered on Jul 20, 2018
Error message on Cannon IR 3300
that is a stack delivery error could be one of the motors or a board do you have the internal finisher or external
3/12/2018 10:15:26 AM • Canon... • Answered on Mar 12, 2018
Cannon IR2318 E000019-0002
Please give me advice how to repair E000019-0002 error in IR 2318L. After printing about 20 pages I got that error code. Please reply me.
1/13/2018 10:58:46 AM • Canon... • Answered on Jan 13, 2018
7answers
E000007-0000
Hello Evank,
I will gladly help you understand what's going on, but I am afraid nothing short of service call will actually resolve your problem. First off, the error code you are getting will cause the copier to just suddenly STOP...... which indeed will cause you to wind up with a paper stoppage but not a true paper jam. I apologize for what is like a distinction without a difference,but i just wanted to give the benefit of as much information as possible.The error code you are getting refers a subsystem of the copier called the fuser, which is a high temperature high pressure area that is common to all copiers. Because of the potential danger of high temp and pressure, all copier manufacturers design their products to be VERY sensitive to monitoring all aspects of the fuser as they do not wish to burn your building down. (bad 4 marketing) The E000007 error code refers to the fusing system. The code basically means that the on board computer of the copier did not get the signal it requires telling it that the fuser was working properly. That in fact it was not turning at the same time /speed as the copier. There is a sensor on this "fusing unit" that detects this speed. Either the sensor is bad, the fusing unit is indeed not turning at the correct speed and therefore is defective, or the dc controller ( a circuit board on the machine that processes most inputs) is defective. Most likely its the fuser/fusing unit which indeed is a "unit" and if it needs to be replaced will include the sensor previously described. The fuser (Canon also refers to it as a fixing unit) is good for @150000 copies more or less according to Canon and that is one of those things that I would call "according to the manufacturer" promises.In short, after this long winded description, unless you are a well trained copier tech, you will need one. But at least I have given you enuff info that you won't get screwed by the "copier dude" . :-) Of course I "IS" one. LOL . Good luck and I hope this helps you at least a little. ...........SPINAL........
9/26/2017 7:54:32 AM • Canon... • Answered on Sep 26, 2017
Ir error code e00202-0001
Change power supply
9/24/2017 4:32:08 PM • Canon... • Answered on Sep 24, 2017
2answers
Ir 3300 mechine e00014 error
ir 3300 mechine e00014 error code please suggestme
9/17/2017 7:06:38 PM • Canon... • Answered on Sep 17, 2017
E000007-0000 errorquick solution in IR
Fixing film rotation error
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the
fixing film sensor does not detect the rotation of the film for 6 sec or more
while the fixing motor is driven.
Main cause: The fixing film sensor (PS45) is faulty. The DC controller PCB is faulty.
Caution: To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Wiring
Are the wring and the connectors connected securely?
DC controller PCB (J311) <-> relay connector <-> fixing film sensor
NO: Connect the wiring and the connectors.
2. Fixing film sensor
Check the fixing film rotation signal.When the fixing motor is rotating, is
the film rotation detection signal sent by the fixing film sensor to the
concoctor J311 of the DC controller PCB?
Film rotation detection signal: 5V pulse signal between J311-A9
(FILM_ROT_D) and J311-A8 (GND); at intervals of 100 msec ON and 440
msec OFF
NO: If the fixing film is normal, replace the sensor.
3. Fixing film unit, DC controller PCB
Is there a fault in the fixing film edge rotation detection mechanism?
YES: Replace the fixing film unit.
NO: Replace the DC controller PCB.
7/29/2017 2:19:51 PM • Canon... • Answered on Jul 29, 2017
Ir 3570 error e000024-0000
E024 The developing assembly connector is disconnected/Disconnection of Toner sensor.
0000 The connection detection signal is absent
continuously for 100 msec. Replace the developing assembly toner sensor. Connect the connector. Replace the DC controller
PCB.
0001 Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
When the disconnection of the wire used for
detecting the connection of the toner level sensor
has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop
cassette feeding).
has been detected for 12.5 min without
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
interruption.
Correct the cable. Replace the sensor.
TRY THIS:
Remove toner and check for broken parts on tube, check the connection of toner assy, reconect all connectors on dc controller pcb.
If you removed the toner assy before the error occcured check if all connectors are properly inserted.
7/24/2017 3:12:47 PM • Canon... • Answered on Jul 24, 2017
Canon ir3300 : When i put paper in bypass tray, sensor dosnot detect this paper......... I have to open and close bypass trays, the signal jam in dosnot apears..........
canon ir 3300i model xerox machine first tray put in the paperbut message load pater not taken printout in the first tray pls help me
6/3/2017 7:18:56 AM • Canon... • Answered on Jun 03, 2017
Firmware for canon ir2200
You must go to the Canon support site for any firmware updates.
4/5/2017 9:24:04 PM • Canon... • Answered on Apr 05, 2017
2answers
Sir my canon 3300 error
what you need to do is just resetting your machine.
1. Press * 28 * on your machine in a quick move.
2. Select copier
3. Select Err.
4. Select Clear then press O.K
5. Turn your machine off for 1 minute and turn it on again.
The error code will not be there anatmoreand your machine will be functioning well.
plz do rate solution if helped
2/14/2017 12:09:24 PM • Canon... • Answered on Feb 14, 2017
Computers & Internet Logo
358 questions posted
Top Canon Computers & Internet Experts
old marine
old marine
Steve Sweetleaf
Steve Sweetleaf
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Canon Computers & Internet
Most Popular Question
cannon ir2318 e000019 0002
  • Computers & Internet
