20 Most Recent Canon PowerShot A75 Digital Camera Questions & Answers
Accidently formatted memory card-seem to have lost pictures that were on it
Hello Dear,
There is no internal memory present in any of the Canon Cameras but you can take your Card to a data recovery expert and your photos can be retrieved 100%.
You are suggested not to use this card any more, as if over written there will be NO chances for Data Recovery.
Joseph Manoj
+91 9352008418
2/25/2021 9:49:00 AM • Canon PowerShot... • Answered on Feb 25, 2021
2answers
Memory card not reading in camera
look into the camera with a bright light and see if any pins are bent where the memory card goes in. also check to see if the card is unlocked and check the card to see if it works in another device.
10/19/2019 5:50:04 AM • Canon PowerShot... • Answered on Oct 19, 2019
7answers
Canon digital camera recall for defective image sensor
Display went purple with lines then finally died this year, contacted Canon at the link below and they paid all shipping (both ways) in less than 10 days I have the camera back and working like new for $0.00, these guys care about their products and customers. If you have this issue contact them and they will handle it right.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&keycode=2112&fcategoryid=221&modelid=9828
7/11/2019 4:11:08 PM • Canon PowerShot... • Answered on Jul 11, 2019
Cannon powershot sd900 lens will not close
work for about 50% of lens errors, but they're worth a try. The list includes:
  1. Remove the batteries and wait a few minutes
  2. Try pressing and holding the Menu, Function, Function Set, or OK while turning on the camera, or otherwise find a "factory reset" option.
  3. Try turning the camera on without a memory card inserted
  4. Place the camera flat on its back and turn it on while holding down the autofocus button, to try to cause the camera to attempt autofocus while the lens is extending
  5. Blow compressed air in any gaps around the lens - or use a shop vac
  6. Use a thin piece of paper or a needle to dislodge any visible bits of grit
  7. Gently tap the camera in an attempt to realign jammed mechanics or dislodge particles (obvious warning: could cause further damage)
  8. Gently push or pull the lens barrel, as a last resort (again, potential for further damage).
12/2/2017 5:46:59 PM • Canon PowerShot... • Answered on Dec 02, 2017
NO memory card Problem - Powershot 550
More likely one of the spring contacts in the camera that connect to the SD card has become weak causing the problem.
10/31/2017 3:59:36 AM • Canon PowerShot... • Answered on Oct 31, 2017
10answers
How to recover deleted photos
For someone who has little knowledge on computer like me, I usually prefer to getting help with some pro programs, such as asoftech recovery program http://www.asoftech.com/apr/or u can visit http://www.asoftech.com/recover/ where I find many guides in detail there.Hope it can help u. Good luck.
1/9/2017 2:27:23 AM • Canon PowerShot... • Answered on Jan 09, 2017
2answers
I need to know how to set the heating and water
Hi british gas will take nothing over 10 years on a contract so don't worry about that there plenty of gas fitters who will bo repiars on i,t hot water should be on for how much you are going to use 2hours in the morning longer in the evening its how much you will use too how long you have it on
3/14/2016 10:32:13 AM • Canon PowerShot... • Answered on Mar 14, 2016
Why does canon camera shuts off when trying to download pics
Usually it's because the battery is getting low. Cameras will often shut down to prevent losing data. Make sure the battery is fully charged or the camera is plugged in if it has an external power adapter.
11/25/2014 9:08:45 PM • Canon PowerShot... • Answered on Nov 25, 2014
How do I unlock memory card on canon power shot a495?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
7/6/2014 4:27:40 PM • Canon PowerShot... • Answered on Jul 06, 2014
0answers
0answers
0answers
0answers
Canon PowerShot A75 Digital Camera Logo
992 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
manual cannon powershot sx510hs lost
  • Cameras
